Brake replacement
Old Mar 17, 2010 | 12:15 AM
Kagen's Avatar
Default Brake replacement
My car is jacked up with the tire off waiting to get its brake pads replaced. My problem is that it doesn't seem to take 7 mm allen wrench, its too small and 8mm is too big
Old Mar 17, 2010 | 12:25 AM
bmorgan's Avatar
Default Re: Brake replacement
Do you have an SRT-6? If so, you need a T45 torx instead of the 7MM hex.
Old Mar 17, 2010 | 01:26 AM
Kagen's Avatar
I have an 04 non srt6 but it has the leather and silver trim
Old Mar 17, 2010 | 08:48 AM
I have not seen any Allen head screws on my car, they are all Torx. These are cheap enough though and easy to obtain at auto supply shops.
Old Mar 17, 2010 | 11:12 AM
kingkub57's Avatar
I would get your self a set of torx bits, and a set of inverted torx sockets for this car. DO NOT use an allen wrench, or anything that is close cause it can round it out or strip it. It is much better to have the right tool to do the job correct and not to damage the attaching hardware. You can get these tools just about anywhere and at resonable prices.
Old Mar 17, 2010 | 04:30 PM
Airscape's Avatar
Don't have time to hunt it down at the moment but if you search for TORX I know there is a thread with a good list of packs to buy that pretty much cover it all. I just ran to Sears and grabbed a few packs\styles (cant remember all of what i got but it was prob in 80-100$ range) and got pretty much every size other than the HUUUUGE ones.
Old Mar 19, 2010 | 10:47 PM
Kagen's Avatar
Found out the size was T45
Old Mar 19, 2010 | 10:51 PM
bmorgan's Avatar
Cool, I had it right, even if I did say for SRT. LOL
Old Mar 20, 2010 | 12:15 AM
Kagen's Avatar
Do you have to compress the brake pad with a clamp to get it back on? I have both pads on the driver side on but I can't get the caliper back on. For the record these are Posi quiet ceramic brake pads
Old Mar 20, 2010 | 12:20 AM
bmorgan's Avatar
Kagen, I used some wood shims against the piston, and then used a large screwdriver to leverage against the shims to compress the pistons back. I did this with the pads out.
Old Mar 20, 2010 | 11:45 AM
MikeR's Avatar
I use the old pad, or a piece of wood, and a C clamp to slowly compress the cylinder back in...
Old Mar 20, 2010 | 11:55 AM
I am with Mike on this one.....getting ready to do the coupe with ceramic pads, metal lines, and new brake fluid....the high performance kind...lol No rotors this time...since I have a spare set...lol
PNA
Nov 12, 2020 04:44 PM
Roty135
17
Oct 11, 2018 10:11 AM
Rooster98
Dec 24, 2015 10:59 AM
Romio
Jul 24, 2015 07:04 AM
Rooster98
Jul 21, 2015 12:39 PM
