Stripped Rear Wheel Hub
Old Feb 4, 2012 | 06:05 PM
robertalive's Avatar
Default Re: Stripped Rear Wheel Hub
brake rotors dont have threads.just tap the rears with a 14mm tap and get the right size bolts.rotors can easly be drilled to 14mm some are 14mm and you can even tap through the rotor as a guide to the newlly drilled bore as a guide,to make sure youre tap is straight.stay away from helicoils as much as i can.just for smaller less demaNDING BOLTS.
Old Dec 9, 2012 | 09:40 AM
MJPowers's Avatar
Pics of Hub replacement.
Old Dec 9, 2012 | 12:14 PM
How did you drill and tap the holes, by hand or in a drill press?
This thread was filled with good advice, bad advice and totally wrong advice.
Old Dec 9, 2012 | 05:11 PM
Pretty good deal if you have stripped threads, best solution.
Not mine.
Old Dec 9, 2012 | 05:14 PM
bluecoupe's Avatar
I saw that Dave, but I thought if I bought it I'm only looking for trouble
Old Dec 10, 2012 | 07:16 PM
MJPowers's Avatar
I did drill them by hand, but I used two right-angle guides for horizontal and vertical. I was happy with the results, but since I autocross almost every weekend in the summer, I end up performing about 100 times the wheel changes most cars see in their lifetime. I did the helicoil fix in 2010 and raced all season with them in 2011. I replaced both hubs last winter and figured that I wouldn't tempt fate.
Old Dec 11, 2012 | 12:27 AM
What would worry me if I did this is the probability of not having the same center as the original and having the new thread not at a right angle to the hub face. This would mean that the ball seat was not contacting the wheel properly and the stud ball was hitting the side of the seat rather than the bottom. You cannot see it so all may seem OK. That is not desirable at all and will damage the wheel to a greater or lesser degree.
Done well the Helicoil should be better than OEM and wear better. The stud would probably wear faster then the Helicoil insert and the stud would wear much faster if the thread was too much off center.
This could be a case where lack of knowledge leads to a problem. Using a cheap Chinese Helicoil tap and insert is not recommended. I did use one once and the bolt was way to loose in the insert.
The torque setting for the studs (81 ft/lbs) is low because the thread engagement is quite short, over torquing the studs leads to stripped threads. Using studs that are too short could easily give you stripped threads even using the specified torque setting.
I'm sorry for the long post but if a few threads were done in a hub incorrectly you may be close to loosing a wheel without knowing it.
Old Dec 11, 2012 | 03:19 PM
MetalMilitiaSRT's Avatar
Thanks Woody. Your post put me on the Helicoil path. The hardest part was drilling the hole, knowing I was at the point of no return for that hub. Between this forum and the folks at Emhart, I felt confident that this was a good solution.
Mike
Tell me about it. I was shaking before I drilled the holes wider on the intake manifolds of my Challenger. A screw-up would be a ±$500 mistake! I installed TimeSerts. They are similar to helicoils but they're solid.
Glad to see it is all taken care of.
EDIT: Wow, I didn't realize this was an ancient thread...
Old Dec 12, 2012 | 05:57 AM
MJPowers's Avatar
Closeup of inside of hub.
Roty135
17
Oct 11, 2018 10:11 AM
cdcrone123
27
Sep 24, 2015 11:28 AM
cdcrone123
Aug 4, 2015 06:37 PM
tom2112
Jul 28, 2015 08:12 AM
Buchacho
Jul 9, 2015 04:13 PM
