Vossen Wheels Anyone??
Old Dec 26, 2010 | 09:01 PM
abraham280700's Avatar
Default Vossen Wheels Anyone??
Hey everyone im a newbe and ive read and researched plenty of useful information on this forum. So here's my question. Have any of you guys every looked into Vossen Wheels? I for one love the VVS-082's black machined wheels but I wanted to get everyone's opinion. How would they look on my Crossfire Limited? Thanks for your comments Thanx!!
Front Wheel Specs:
Rim Size- 19x8.5
Offset- 30+
Bolt Pattern- 5x112
Rear Wheel Specs:
Rim Size- 19x10
Offset- 36+
Bolt Pattern- 5x112
Old Dec 26, 2010 | 09:11 PM
bmorgan's Avatar
Default Re: Vossen Wheels Anyone??
Dang..... Those are some extremely sick wheels!!!! I think I just found a new favorite. They even look good on American muscle:
Or, a BMW....
Old Dec 26, 2010 | 10:05 PM
They do look Good dont they!!!
Old Dec 26, 2010 | 10:10 PM
bmorgan's Avatar
I have been leaning towards the Lexani LX-10s, but now these have me scratching my head. Both would be great options though.
Old Dec 26, 2010 | 10:27 PM
Do you think I would have any issues with the fitment?
There are some sizes that i am interested in mounting in the rear.
Specs:
Rim Size: 20x10.5
Offset: 30
Do you think this would be a nightmare?! Specially if im looking to lower my N/A.
Old Dec 27, 2010 | 12:26 AM
bmorgan's Avatar
Check this out. https://www.crossfireforum.org/forum...ment-tool.html
Old Dec 27, 2010 | 09:16 AM
Specs:
Rim Size: 20x10.5
Offset: 30
It is not the rear you will need to worry about if you are running a 19x8.5 in the front. I ran 20x8s up front and even at 8" wide, they were too wide (with OEM offsets) and I had to use spacers. It takes a lot of time and some guessing to know if wheels you do not have will fit a car you have not lowered yet. Good luck.
Old Dec 27, 2010 | 11:33 AM
durdenss's Avatar
It is most certainly the rears you have to worry about. as well as the front, your 8.5 fronts did not work because you had a higher offset than you needed to have. many people have run 8.5's in fronts with no problems they just had the correct offsets. The rears you are posting, abe, would not work with that width. it would sit too far in, probably hitting suspension components. the stock rear wheel is +22 on a 9 inch rim. the higher the offest the more it sits inside the wheelwell. the lower the more it "pushes" it out. the offset is how far it sits from the centerline of the wheel. like bmorgan said use the fitment calculator.
Old Dec 27, 2010 | 12:24 PM
Larry Hitze's Avatar
Good looking wheels!
Old Dec 27, 2010 | 01:48 PM
Well I already went through the fitment tool. It shows the wheel will be recessed 1" from where it is now. Still unsure whether it will fit or not. I looked under the car today it seems that it will fit no problem. But the 20x10.5 will not . I will stick to the 19x10 hopefully all will go well.
Old Dec 27, 2010 | 05:24 PM
bmorgan's Avatar
The stock wheels need 15MM spacers to give it a clean look like the BMW pictured above. If these are going to be inset another inch, no spacers could safely counter that. Do they not have any other offsets that would get them closer?
Old Dec 27, 2010 | 06:05 PM
i believe the other offsets available are much greater then 35. I love the wheels i hope i can make them work somehow. they have a 20x10.5 with a 30+ offset too. Maybe I can make that work.
Old Feb 13, 2011 | 10:33 PM
nick78ru's Avatar
My cousin has those on his Infiniti G37s. Those are rather expensive but extremely good looking wheels
TerryR
Dec 13, 2019 03:27 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
Oct 1, 2015 01:42 AM
Mackel
Sep 29, 2015 02:41 PM
ritous1
Sep 26, 2015 01:27 PM
