Is there a dust cap puller?
Old Mar 21, 2011 | 10:58 AM
martininmia's Avatar
Default Is there a dust cap puller?
Hi Crossfire fans. My first time posting, am enjoying all the great info on this forum. Is there a particular trick or tool required to pull the front wheel dust cap? Need to replace the bearings and can't seem to be able to pull the darn things off. I've got a 2005 with ~50k on it and I bet they have never been pulled - are a bit rusty at the point of contact. Thanks for any input - Martin
Old Mar 21, 2011 | 11:01 AM
LantanaTX's Avatar
Default Re: Is there a dust cap puller?
You may want to replace the dust cover with the bearing. If so, channel locks or vise grips will get it off.
Old Mar 21, 2011 | 11:04 AM
Thanks for your quick reply! I already poked a hole in one of them, trying to punch it off with a screw driver.
Old Mar 21, 2011 | 11:18 AM
MikeR's Avatar
Yes, they SHOULD just pry off..... looks like new ones are in your future...
Old Mar 21, 2011 | 02:25 PM
freakingfastsrt6's Avatar
Very common!!! And no there is not a dust cap puller! So rip em' off and get some new ones! Make sure to grease the new ones before install...as they rust along the hub.
Old Mar 21, 2011 | 03:51 PM
mophreakous's Avatar
Got mine off with a small chisel and hammer(tap tap tap), no damage done....
syfi
Mar 28, 2026 04:14 PM
4drturbo
21
Nov 12, 2018 04:50 PM
ritous1
Sep 26, 2015 01:27 PM
RacerXofFL
Sep 15, 2015 05:00 PM
MickeyNasty
Sep 6, 2015 08:29 PM
