Srt 6/ NA oem rear shock replacement are lowered info
Old Oct 28, 2011 | 03:03 PM
texas t's Avatar
Post Srt 6/ NA oem rear shock replacement are lowered info
Hey, guys i"m trying to replace my rear shocks on my srt6 ,i bought Bilstien replacement"s they do not fit they are to long new ONES 20" old 181/4. Can fined no spec"s on aftermarket shocks other than monroe they show p/n 39045 which has same spec"s as the oem"S. Bilstien, offers a sport shock for lowered cars which are supposed to be shorter! cAN FIND NO SPECs
Has anyone replaced their rear shocks without lowering. If so please list part # with length if you have them.
I checked factory replacement shocks which are made by Zf sachs Chrysler want 330$ to 550$each for replacements oucH
Now if you have replaced r shocks when lowered can someone measure them for length and travel and then compare the to the monroe info below
http://catalog.monroe.com/catalogPar...layPartDetails
Old Oct 31, 2011 | 03:55 PM
texas t's Avatar
Default Re: Srt 6/ NA oem rear shock replacement are lowered info
BUMP anyone??
Old Oct 31, 2011 | 06:23 PM
SilverWolf's Avatar
I can't help you with any measurement but, I can tell you that when I installed Konis on my 6, I noticed they also were nearly 2 inches longer than the oem shocks. I was assured by Koni that they would fit fine and there would be no bottoming out. I'm not lowered and I've had no issues whatsoever in 6 months on the Konis. Although, I do wish I'd taken photos and measurements for future reference.
Old Oct 31, 2011 | 07:07 PM
syfi's Avatar
Hey T,
I have been running on the KYBs on all corners for a couple of years now and couldn't be happier. I'm not lowered but several guys run them on lowered setups with no problems. You can read Lantana's comments about them here:
https://www.crossfireforum.org/forum...ew-shocks.html
KYB Gas-A-Just Monotubes - Front part# KG4731 and Rear part# KG4732
You can find them @ Rock Auto for around $55 ea. fronts & $63 ea. rears.
You may also still find them on Ebay, where I found mine.
Just search under the 2001 SLK320 to find them.
Also...Summit has them for $57.07 ea rears.
http://www.summitracing.com/parts/KYB-KG4732/
These are a great upgrade from the OEM Sachs twin-tubes.
Here's the specs for the rears....
Adjustable: No
Body Diameter: 39.2 mm
Body End Type: See Upper mount/Lower mount
Body Material : Steel
Boot Included: No
Bushing Color: Black
Bushing Material: Rubber
Coil Over Springs Included: No
Collapsed Length: 15.28 in
Color/Finish: White or silver paint
Diameter: 39.2 mm
Dust Shield: Yes
Extended Length: 18.9 in
Gas Charged: Yes
Hardware Included: Yes
Internal Design: Monotube
Line Fitting Quantity: 0
Lower Mount Type: E2(10x40)
Lower Mount: E2(10x40)
Mounting Bracket(s) Included: No
Mounting Hardware Included: Yes
Shock Type: Performance Monotube
Travel Distance: 3.62 in
Type: Performance montube
Upper Mount : S1
Valving Selection Quantity: 0
Old Nov 1, 2011 | 12:59 PM
texas t's Avatar
Thanks guys, for the info. I must be doing something wrong! I installed using all the oem old mounts and it rides like a car with no springs and a very loud noise when crossing very small bumps in the road! I have installed many shocks and never had a problem! Danny
Old May 11, 2013 | 03:39 PM
FUBU's Avatar
Did you solve this?
MJPowers
Jun 8, 2015 02:34 AM
blackcross
Jan 22, 2004 01:18 AM
WilliamT
Nov 28, 2003 11:31 AM
fire
Oct 14, 2003 07:00 PM
Pneesam
Sep 19, 2003 09:42 PM
