Traction Control
Old Jan 23, 2012 | 05:44 PM
bruce001's Avatar
Default Traction Control
I just bought my xf and notice the "traction control" is faintly illuminated. Is that normal? Or should it be completely out? When I switch it off it gets brighter.
It is barely noticeable.......but wanted to know if there was a problem.
Old Jan 23, 2012 | 06:21 PM
Default Re: Traction Control
you have a problem.... it will light up if you are slipping...like spinning the tires but shouldn't be lit unless off...
Old Jan 23, 2012 | 06:46 PM
bruce001's Avatar
It is very faint....can you see yours at all?
Old Jan 23, 2012 | 07:34 PM
bluecoupe's Avatar
If you turn the TC off you'll see the light. What I think you may be seeing is the TC image appears to be faintly lit during bright daylight. Drive it at night with the TC on if you still see a faint image, you have a problem..........not with the TC but some other light bleeding into the TC image.
Old Jan 23, 2012 | 08:29 PM
bruce001's Avatar
I think you broke the code....it is noticeable in the sunshine with the top down......I'm in Florida right now and have had the top down all the time.
syfi
Mar 28, 2026 04:14 PM
johnnycross413
Mar 4, 2016 04:49 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Billy22Bob
Sep 26, 2015 10:16 PM
