Posi-Quiet Ceramic pad set?
Re: Posi-Quiet Ceramic pad set?
I feel very fortunate to have had no issues or concerns with my Posi Quiet pads.
Have had them on since last May and they work great !!
https://www.crossfireforum.org/forum/593170-post75.html
https://www.crossfireforum.org/forum/593503-post77.html
https://www.crossfireforum.org/forum...8-post113.html
I also reseated the emergency brake by going backwards a few times and pumping the brakes.
Also the rear pads can be changed very easily without removing the calipers.
Glad everything worked out for you. James
As usual James1549, your spot-on 100%. I just grabbed my trusty service manual set and verified (Page 5-59 middle page) the correct proceedure for adjusting the E-brake. I love this forum! Doncha just love the fact a US car has had auto-adjusting E-brakes since mid 70's standard, and a 2004-2008 Chrysler (of MB origin) doesn't? One of the best investments I made was this hard copy service manual set!
As far as the hard copy service manual being a good investment depends on your outlook I guess. I have it as well as a CD version, but I always look on the computer and print out the sheets relevant to the job in hand from the copy I down loaded from this site. Why have the big manuals in the garage when a couple of disposable sheets of paper do the job?
on
I am not sure the E brake could be said to be self adjusting even on the cars you are refering to, the rear shoes on a drum style brake did adjust automatically in reverse as long as the adjusting screw had not rusted up. But the cable assembly still required adjusting to take up the slack due to stretch when used often, so in essence it was not self adjusting, American car or not. Most people driving autos never used the E brake anyway and the cables often rusted up as a result.
OK, I hear ceramic pads are good for the reduction of brake dust but I also hear they accellerate the wear of the rotors. How concerned should I be with premature rotor wear, about how many miles should I expect to get from the OEM rotors before I have to replace, and are there stronger rotors I should consider when replacing them? Thanks guys, I know this forum is the absolute best in helping members take great care of their cars and saving thousands of hard earned bucks!
on
Gentlemen - I just installed a set of Centric "Premium" ceramic pads and Goodrich Stainless braided brake lines, per Rob at Needswings, and they are great. Good stopping power and distance, no noise, and a GREAT FIRM pedal feel. Couldn't be happier! Give Rob a call.
Jim
Jim
LantanaTX
09-30-2007 04:05 PM
