can lower offset cause vibration
Old Mar 21, 2012 | 02:45 PM
roadstermiketx's Avatar
Default can lower offset cause vibration
I recently put new rims on my roadster and the offset was a little lower on the rear, can this cause vibration? I have been feeling a lot of vibration at higher speeds...thanks guys!
Old Mar 23, 2012 | 12:46 PM
freakingfastsrt6's Avatar
Default Re: can lower offset cause vibration
Incorrect balancing...Or tires= bad tire wear, or tires overall, And did you buy the wheels new or used? Maybe a slight bend in the wheel. Offset would not cause a vibration in the rear. If they were upfront that could be the case, but not from the rear.
goodluck
goodluck
Old Mar 23, 2012 | 08:25 PM
32krazy!'s Avatar
are the wheels hubcentric? if not theres your vibration
Old Mar 23, 2012 | 11:30 PM
how would I find that information out? I have no idea if they are or not and can that problem be fixed if they aren't?
Old Mar 23, 2012 | 11:33 PM
and FREAKINGFASTSRT I've had the tires rebalanced just in case and they told me they're fine...new tires overall and the rims are brand new only had for a month...
Old Mar 24, 2012 | 07:05 AM
32krazy!'s Avatar
ask the shop you bought them from or pull the wheel and look. there should be a lip on the backside that rests on the lip on the hub. what model wheels? whats the hub bore? were hubcentric rings included in the buy?
Old Mar 24, 2012 | 07:46 AM
One thing that I would look at, are the lug bolts matched to the rims? My OEM require ball seat bolts, many aftermarket rims use tapered seat bolts. This may cause a wobble.
55chevy
Jul 22, 2024 02:31 PM
Oct 1, 2015 01:42 AM
Power Sedan
Sep 20, 2015 09:24 PM
ayebb
Sep 18, 2015 03:35 PM
waldig
Sep 17, 2015 10:35 AM
