Suspension Suggestions?
Old Feb 8, 2013 | 12:32 PM
Airscape's Avatar
Default Re: Suspension Suggestions?
If you lower you will need something eventually. You technically don't have to get anything extra but you will eat through tires quickly. To do the job right you will need something to at least adjust camber front and back. If you have an SRT, swapping to NA springs and konis would soften up your ride but you wouldn't be any lower. (Would also lose some handling)
Old Feb 8, 2013 | 09:21 PM
2008XF's Avatar
i have a NA, so if i get Konis and keep the stock springs would that be good?
Old Feb 9, 2013 | 12:05 AM
Selbyl's Avatar
Originally Posted by 2008XF
Hi guys thank you so much for all the information.
could you guys recommended a setup where I would not need to do any additional work or need any additional parts.
I think I read on here if you just throw on Eibach springs with the stock shocks you shouldn't need any extra parts.
I'm still trying to figure out how I'm going to lower my car without spending a fortune, so I'm in the same boat.
Old Feb 9, 2013 | 07:33 AM
shaag78749's Avatar
That's what I did. Since the car retains the original ride height, there is no need to adjust the camber. The Koni Sports are adjustable; so you can adjust the ride quality with a turn of a ****. I run mine with the fronts about one turn from full firm on the street and set them on full firm for autocrossing. The rears are set in the middle of the adjustment range. The handling is much improved over stock. Tires (mine are Michelin Pilot Super Sports) also really improve the handling. You won't be disappointed with Koni Sports, and installation is really easy.
Old Feb 10, 2013 | 02:58 PM
2008XF's Avatar
Thanks, i think this is the route i will go.
Old Feb 16, 2013 | 06:03 AM
speedfiend's Avatar
While discussing these rear camber adjusters, nobody seems to mention that some kind of compliance is required in the suspension joints, and large ball joints with the kind of surface area provided by the K-Mac bushes will give durability allied with that compliance as they are encased in urethane.
This in addition to adjustability.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Dementors
Sep 30, 2015 07:46 PM
ozkancab
Sep 25, 2015 10:55 AM
