275/35/19 rears
on
Re: 275/35/19 rears
My car tires are stock front and 275/30/19 rear w/o causing ESP issues. Here's a tire calculator that can be usefull to ppl concerned with keeping speedometer accuracy, OE diameter and ESP happy!:
Tire Size Calculator - Compare Tire Sizes
By first entering the OE size and then an alternate size, you can better visualize what change it will have on your car. If you want to go wider in the back while keeping the same diameter, size 285/30/19 is a close match
on
Re: 275/35/19 rears
I run 285/35's on the rear and it actually helped my speedo accuracy. Before, an indicated 80mph was about 78mph on my GPS. NOW, 80 on the dash is 80 on the GPS and my engine rpms are down from about 3000 at 80 to something like 2800.
A bit less power, sure, but once you get the car rolling I'd think that just keeping it in a lower gear a bit longer compensates - it's why the car has a stick in it!
Anyway, from this, I believe the speedo to be driven by the sensors in the front wheels... am I right?
on
Re: 275/35/19 rears
I dont know but my guess is, like most cars, speed is calculated with trany output shaft speed sensor. Therefore, your actual physical speed will be altered when you change tire diameter on the driven wheels only
Re: 275/35/19 rears
Enlarging a tire's diameter by as little as an inch will make a 3.27 gear perform more like a 3.07.
Yes it will get slightly better gas mileage, but that's what my "Honda" is for.
Re: 275/35/19 rears
Have a nice one
/Adam
usprb1976
04-04-2024 04:57 PM
2005 Ragtop
10-03-2015 03:01 PM
