wheels
Old Sep 17, 2013 | 11:06 AM
austinbarrylee's Avatar
Default wheels
i ordered new rims for front and back. I order 19x8.5 32 offset for the front and back. Will I need spacers. I am looking to run nitto motivo 255/35zr/19 for rear and 235/35ZR19 for front. can anyone give me advice if this would work or should I get another tires size. I already have 255/35zr/19 on stock srt6 rims. I was just going to switch out rims. its srt6 lowered wit eibach springs. thank you
Old Sep 17, 2013 | 12:32 PM
Default Re: wheels
you are using the stock size ,,255/35-19 the tire is 10" wide,,3.5 sidewall and 26" tall,
the stock rims have a offset of 35 on the front and 25 on the rear,, it may fit or you may need spacers to move the wheel out ,,when mounted ( if there are no rubbing) check if the rear tires line up (track)with the front,, or stick IN more than the front. jim
TerryR
Dec 13, 2019 03:27 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
Oct 1, 2015 01:42 AM
Mackel
Sep 29, 2015 02:41 PM
ritous1
Sep 26, 2015 01:27 PM
