Do I Need Spacers
Old 03-30-2014, 01:22 PM
Iamfink2's Avatar
Default Do I Need Spacers
I just bought a set of Sport Edition ST4 wheels for my roadster and need to know if I need spacers on the rear. The stock offset for the front is: +35mm and the rear is: +22mm. My new wheels are front: +32mm which I'm good without any spacers but the rears are: +36mm a 14mm(roughly 1/2 inch) difference from stock. I'm leaving for the Tail of the Dragon on April 3rd and won't have the spacers by then. Is it alright to drive with a 14mm difference on each rear wheel or should I leave stock wheels on till I get back? I don't want to damage the wheels or drive an unsafe car while at the Dragon. Thanks, Pat
Old 03-30-2014, 01:32 PM
Iamfink2's Avatar
Default Re: Do I Need Spacers
These are the new wheels.
Old 03-30-2014, 01:56 PM
velociabstract's Avatar
Nice wheels! The rears will "most likely" rub the inner fender wells aggressively. Put them on and see. Going around the block won't hurt anything even with a bad rub. I see a 12mm or 15mm spacer in your near future which means you'll need longer lug bolts too. The perfect offset will depend on how wide the rear tires are. If stock both 12mm and 15mm will work.
You definitely can't have a rub at speed cornering at the Dragon. Rubbing has the same affect as applying just the rear brakes. The rear of the car will snap loose on you.
Les
Old 03-30-2014, 04:23 PM
Iamfink2's Avatar
Thanks for the quick reply, thats what I kind of figured but I thought I'd just put it out there for opinions. I've never had to use spacers on other cars before.
maxcichon
05-14-2019 07:30 PM
grip grip
31
09-27-2015 10:06 PM
09-26-2015 10:21 PM
04Fire
09-15-2015 07:40 PM
Buchacho
07-09-2015 04:13 PM
Quick Reply: Do I Need Spacers
