Mandrus Rotec wheel bolt length?
Old Nov 17, 2015 | 09:25 PM
csteve0355's Avatar
Question Mandrus Rotec wheel bolt length?
I'm just about to pull the trigger to buy these wheels without using spacers, and I have talked to 5 different companies and have got 3 different answers to bolt length. Two say 24MM, two say 28MM and one says 27MM. I'm hoping a Forum member who has installed Mandrus wheels can help me with the correct answer to length so as not run the bolts into the emergency cable.
Thanks...Steve
Old Nov 17, 2015 | 10:47 PM
ATX SRT-6's Avatar
Default Re: Mandrus Rotec wheel bolt lenght?
I'll be getting a set Thursday myself.
Old Nov 17, 2015 | 11:04 PM
csteve0355's Avatar
Did you get wheel bolts with you order?
Old Nov 17, 2015 | 11:23 PM
ATX SRT-6's Avatar
The Discount Tire manager ordered them from their stock list but I'm not sure on the length.
We did discuss the need for proper length and conical vs ball seat on the lugs. I'll let you know after I get mine. You could probably call Mandrus and ask them.
Old Nov 18, 2015 | 12:11 AM
csteve0355's Avatar
Keep me informed as this was one of the company's that I called - I'm hoping the length is on the packaging - and once you get the rim on the car and spun around to see if it hits the emergency brake cable - I read somewhere that the bolts should turn about 7 full turns to tight to be safe.
Old Nov 18, 2015 | 08:35 AM
pioneer4x4's Avatar
Default Re: Mandrus Rotec wheel bolt length?
Get the longer ones, and grind off any excess.
Red Runner
Sep 15, 2025 12:49 PM
rmcdaniel12
Nov 25, 2015 08:12 AM
bbsrt6
Nov 19, 2015 06:53 PM
jaws
Oct 27, 2015 09:35 PM
c-xfire
Oct 26, 2015 07:16 PM
