Finally, TPMS bypass on my '08
Old Feb 3, 2016 | 10:00 PM
Default Finally, TPMS bypass on my '08
... Deleted ...
Old Feb 3, 2016 | 11:22 PM
Steve Jr's Avatar
Default Re: Finally, TPMS bypass on my 08
My TPMS lights were doing the exact same thing, but what I did ,was raise my tire pressure by 2 psi in each. No more light. Of course weather has warmed back up now, guess time will tell.
Old Feb 12, 2016 | 07:51 PM
... Deleted ...
Old Feb 13, 2016 | 06:18 AM
I forgot to mention I checked the tire pressures, they were 32/33 respectively.
Like others, I keep my tires around 36 psig and have never had the TPMS light come on. I'm wondering if the system is sensitive enough that, when the tires are at or near factory recommended pressure, the warning light will come on. Your comments would indicate that this wasn't the case before and is a new issue.
Interesting!
Old Feb 15, 2016 | 02:28 PM
pioneer4x4's Avatar
Default Re: Finally, TPMS bypass on my '08
ALso, it is worth mentioning, that any issue that 2-5 psi might cause such as the light coming on when cooler, you should always check with different gauges. I knew someone that was a total nut about air pressure because of something he read. And he kept a gauge in every car, and checked every week. It ended up that the 3 gauges he had would read something like 28,30, and 35 on the same tire. Never trust 1 gauge, or 1 tire pump, if you care about how exact the reading is.
Old Aug 30, 2024 | 09:17 PM
jmontana's Avatar
When I joined the family, I observed my F-I-L check his tire pressures and fluid levels every weekend. All fluid levels, not just the oil. I thought that was weird but... when in Rome...
Later on when cars didn't need as much weekly attention, I stopped copying his habits. Perhaps there was a bit of knowledge there that should have stayed in my brain?
maggy13
Aug 2, 2019 10:01 AM
TiredRetired
25
Jul 1, 2017 06:40 PM
theglot
Dec 6, 2014 08:33 PM
onehundred80
Jan 20, 2012 06:44 PM
sweldon2
Jun 10, 2008 07:04 PM
