Hypothetical wheel fitmit
Old 08-03-2018, 09:51 PM
Default Hypothetical wheel fitmit
If you were to use the factory front wheels and factory tire size, on all four corners, would spacers be needed to make the rear offset correct? If so, how much? Thanks, James
Old 08-03-2018, 11:20 PM
Default Re: Hypothetical wheel fitmit
the front is 30 offset the rear is 20, but the rear rim is a lot wider, so play with it. ,so you would need a 10mm hubcentric spacer also check you lug bolts length the front can use stock ones ofcourse ,, lenght needs to be 6/8" sticking through back of rim front can be longer check the front and rear when u remove the wheels. rear can not stick through more than 6/8" 1/2 would work this would be through the rim and the spacer ,,just to be safe, spin the wheel,,, once tight ,,,listen for lug bolts hitting em brake cable
Old 08-04-2018, 04:26 PM
Thanks Jim.
Clarkcou
03-18-2018 05:22 PM
FUBU
09-04-2012 03:33 PM
uknowhim21
04-24-2012 07:38 PM
blackcrossfire07
09-08-2009 02:00 PM
+fireamx
10-23-2007 10:38 PM
Quick Reply: Hypothetical wheel fitmit
