Front wheel spacers
Old Mar 21, 2019 | 10:01 AM
Ajbarbier's Avatar
Default Front wheel spacers
Does anyone know of some front wheel spacers that will work for our car? I tried getting a few pairs that match the center bore but nothing will clear the dang grease cap. If anyone has some brands let me know. Best,
aj Barbier.
Old Apr 13, 2019 | 07:46 AM
Ajbarbier's Avatar
Default Re: Front wheel spacers
Or what diameter hub centric rings? I just see sizes ike 66,6mm to 76mm. Would i want to just stick with 66,6?
Old Apr 13, 2019 | 08:18 AM
You asked the same question in October and January, and there are many more threads on this subject. Surely you can find a solution to your question on here somewhere. The answer was given and you ignored or missed it. The bore has to be lengthened to clear the grease cap.
I think you should save your money, new spacers and new bolts ain’t coming cheap. Spacers are not really mechanically sound, just hope the bolts are tightened or you may be in dire trouble.
You may notice 10mm or so but let’s face it nobody else will.
Old Apr 13, 2019 | 12:17 PM
Ajbarbier's Avatar
Alright 180, I was just wondering because I had not been able to find a specific answer on the hubcentric rings. Talked to a guy a while ago but never got back to me.
Old Apr 13, 2019 | 01:45 PM
You must use hub centric spacers, 66.6 inside diameter, they must clear the grease cover and the bolt pattern must match the hubs.
I was going to do a drawing similar to the one by James1549 but never got around to it.
The minimum spacer thickness is 10 or 12mm, I cannot remember which.
The inside bore must be the length of the hub location diameter plus clearance for the grease cover plus a thickness where the 66.6 ID transitions to 66.6 OD. I’d guess this should be about 3 to 4mm.
Old Apr 13, 2019 | 05:25 PM
DHS's Avatar
DHS
EZAcessory is where I got the 10mm hubcentric that I am using on my NA with SRT wheels, this is due to the 345mm calipers. Not sure if the SRT front hub is different.
Old Apr 13, 2019 | 06:47 PM
Ajbarbier's Avatar
Awesome. will check EZ then.Thank you.
Old Apr 13, 2019 | 06:50 PM
Ajbarbier's Avatar
Billet Hub Centric Wheel Spacers 5x100 / 5x112 Audi 10mm
DHS, are these the ones youre running up front?
Old Apr 13, 2019 | 10:23 PM
DHS's Avatar
DHS
10mm (Pair)
Billet Hub Centric Wheel Spacers Mercedes 10mm (Pair). This what I have, keep looking on their site, not easy to find, or just call them.
Old Apr 13, 2019 | 11:31 PM
Originally Posted by DHS
10mm (Pair)
I laugh when I see the word billet in the description of parts for sale, as if it added to its quality.
I just means it was machined from a block of material.
Old Apr 17, 2019 | 02:53 PM
Ajbarbier's Avatar
Hey DHS, just wanted to clarify. You’re saying they work for front spacers correct? Just want to make sure before I place my order
Old Apr 17, 2019 | 03:23 PM
DHS's Avatar
DHS
Yes this what I have on the NA using SRT wheels they have the hub centric you need. Remember you MUST use longer 50mm bolts.
Dan
Old Apr 22, 2019 | 11:02 PM
JEFASOLD's Avatar
aj Barbier.
Try removing the grease caps putting on wheels and spacers then reinstall grease cap. I found some 15mm for front and 20mm for back on the internet years ago and have been riding on them since 2013.
maxcichon
May 14, 2019 07:30 PM
Ajbarbier
Oct 22, 2018 09:02 AM
Clarkcou
Mar 18, 2018 05:22 PM
andrew
Apr 19, 2004 12:01 AM
andrew
Apr 18, 2004 11:01 PM
