Leaking Rear Brake Hose replacement?
Old Apr 26, 2019 | 09:12 AM
Candyman's Avatar
Exclamation Leaking Rear Brake Hose replacement?
Hello Fellow Crossfire owners.
My wife has a 2003 Crossfire Coupe, which she hardly uses. In fact it has only done 26K genuine miles. The problem is that where it has been parking outside for long periods, moisture has corroded the brake line just under the offside door. I have contact several breakers but due to safety, they wont break this part. I have no idea where I can get one from or how much it will cost. Most of the time that I search online for this part, all I can find is the short hose/line rather than the long hose that runs the length of the car. I have made a temporary fix using cable ties but it hasnt really worked as the brake fluid level continues to drop.
With all of the expertise and knowledge on this forum, I am hoping you can point me in the right direction where I can order one from and whether there is a part number that I should be quoting?
MOT is due next month so no point wasting my money until I have fixed this issue.
Thanks in advance for any help you can offer.
Old Apr 26, 2019 | 09:23 AM
Default Re: Leaking Rear Brake Hose replacement?
Were it me, I would just buy tubing the same size, bend it to shape and swadge the ends if needed.
Might have to buy a swadgeing tool and a tubing bender.
Old Apr 26, 2019 | 09:27 AM
Candyman's Avatar
Smile Re: Leaking Rear Brake Hose replacement?
Thanks for the quick reply ala_xfire. I dont know enough about cars and when it comes to the brake system, I really wouldn't want to piece something together that isn't made to fit the crossfire. I could go to my local car parts supplier and ask them if they can provide something like that. Thanks for the idea.
Old Apr 26, 2019 | 11:07 AM
Get it done by a good mechanic, by the time you buy the tools you could be back on the road and have no further use for the tools.
Old Apr 26, 2019 | 06:40 PM
Jim Holian's Avatar
Like 180 say's - take it to a qualified brake shop and forget buying the tools unless you plan on doing the same thing for others. You didn't say, or I misread, where you are located but I wouldn't drive very far with cable tie's to depend on for my brakes.
Jim
Old Apr 26, 2019 | 09:24 PM
Jim
He comes from Chingford, London in the UK, that is on the edge of Epping forest as I recall, l have been there a few times when I lived in the UK.
A brake line is a brake line is a ......
DP XFIRE
Oct 14, 2013 09:14 AM
Berkshire_Crossfire
U.K.
Jan 13, 2012 04:40 PM
crymar
Sep 27, 2011 10:55 AM
amgstyle
Aug 9, 2010 07:10 PM
vaiodude
Jul 1, 2009 08:02 AM
