Sealant tank leaked out in the storage compartment. How to clean?
Old Jan 9, 2024 | 02:12 PM
Esinclair's Avatar
Default Sealant tank leaked out in the storage compartment. How to clean?
My tire sealant tank leaked out in the storage compartment. Can anyone suggest how I clean the mess? It's wet and gooey.
I have a spare cylinder I just bought off ebay, but other than that, are these things still available?
Is there any reason to keep the leaking cylinder?
Old Jan 9, 2024 | 05:40 PM
DTMenace's Avatar
Wink Re: Sealant tank leaked out in the storage compartment. How to clean?
Esinclair
How about a wet/dry shop vac, or a ladle or a turkey baster and a bucket?
Dennis
DTMenace
Old Jan 9, 2024 | 10:32 PM
Default Re: Sealant tank leaked out in the storage compartment. How to clean?
I would get rid of the leaky tank. Tire Slime makes a cylinder like ours. I have a tire repair kit in my tool bag. I also carry a can of Fix-A-Flat for an emergency.
Wear nitrile gloves and try scooping out as much of the stuff as possible. Then use rags to wipe up what you can. What ever residue is left maybe use goo-be-gone or some other cleaner on a rag and wipe it up.
Old Jan 10, 2024 | 07:15 PM
dcskmail's Avatar
Don't replace with one of the original tire sealant tanks, there are some available but they are way out of date and you may have the same problem you have now
Old Jan 13, 2024 | 03:39 PM
Nelson G's Avatar
you can use this instead: https://www.griotsgarage.com/12v-tir...repair-system/
The solution in your car should be water-based, and clean it with water before you put a chemical on it.
Old Jan 13, 2024 | 04:58 PM
Esinclair's Avatar
thanks. i have a compressor, do you think their refill would work?
Old Jan 13, 2024 | 05:11 PM
Nelson G's Avatar
email them. It says it was made in Germany it might be the same product
Old Jan 13, 2024 | 11:36 PM
I took mine out of the trunk years ago and replaced it with a plug kit. I would not have used it anyway as it causes too much mess and damage to the sensor.
I have had two flats with my Crossfires, one was a screw and I fixed it with a plug. The other was a slash in the sidewall and a new tire fixed that.
4shaw
May 24, 2022 01:24 PM
goodgenes79
Dec 16, 2012 10:28 AM
robertalive
Mar 7, 2011 10:12 AM
Gilbert
Sep 19, 2008 05:10 PM
The Toy
Jul 17, 2006 07:39 PM
