brakes questions
Old Jan 5, 2025 | 12:31 PM
dennisoates's Avatar
Default brakes questions
2005 Roadster Limited 26,000 miles
The brakes seem to work ok, but the pedal travel does not seem right. Any suggestions?
thanks
Old Jan 5, 2025 | 03:15 PM
Default Re: brakes questions
How long since they were bled?
Old Jan 6, 2025 | 01:28 AM
thanks
Have the brake hoses been replaced? When they get old they expand easier under pressure and can cause a soft pedal.
Also as Mark stated, flushing and replacing the brake fluid is important.
Old Jan 6, 2025 | 09:17 AM
dcskmail's Avatar
I would inspect the brakes, change hoses ( optional) , bleed wheel cylinders & completely replace all the brake fluid. If you have a manual transmission also bleed the clutch slave as it uses the same brake fluid in the master cylinder. Stop Tech Braided Stainless brake hose available at Amazon : part # front 950.35001 rear 950.35500
Old Jan 6, 2025 | 12:52 PM
Nelson G's Avatar
I use a Schwaben brake bleeder https://www.ecstuning.com/b-schwaben.../007311sch01a/
In the kit, it has an adapter that fits the master cylinder. I have used this for years and find that it works well and my wife is not coming out to the garage so this is just as good.
I will state that I have a Quick Jack that makes it easy as I remove all four wheels and then I can move from corner to corner easier.
And as others have said it's worth replacing the brake lines with SS lines. https://www.buybrakes.com/2003-merce...brake-line-kit
Wedgehead
Apr 13, 2022 06:47 PM
Timesnow
Apr 17, 2014 10:45 PM
Diabloflash
Aug 2, 2013 08:25 AM
CoupeGirl
Jan 20, 2008 07:08 PM
Maxwell
Jan 4, 2008 07:19 PM
