Weisslicht LED Headlights?
on
Anyone heard of these?
WeissLicht Illustro LED Headlight/Fog Light Bulb From bimmian.com
Sold through Bimmian, if you dig down enough, it says the do make H7's.
Interesting.
Gotta' look even deeper for ordering...
Interesting.
on
Re: Weisslicht LED Headlights?
Survey says:
Dear Valued Customer:
Hello, Thanks for taking the time to ask us a question about our WeissLicht Illustro LED Headlight/Fog Light Bulb
Yes they do work for any H7 Housing with standard clearance!
Please feel free to add them directly to your cart by clicking here:
www.bimmian.com/SHELLEY~WLHXX7B1Y
If you wish to return to the WeissLicht Illustro LED Headlight/Fog Light Bulb page where you originally submitted your inquiry, please click
BMW Accessories Lighting and Carbon Fiber from Bimmian for M3 F30 E90 E92 E46 M5 E60 F10 X5 Z4
--- Your original inquiry:
Will the H7 LED headlight lamps work for any H7 housing? Not a BMW. My other car is a Crossfire.
on
on
As is with any light lumens or candlepower is a rating. What is the standard H7 VS the LED H7?
In this test the LED is not even close in light output...
https://www.youtube.com/watch?v=Bhi6P1thtRQ
If it's OK with you, I'll investigate further. OK?
I'm sorry to disappoint you gentlemen, but these will not work anywhere near as good as an HID setup would in our housings.
LEDs simply do not have the needed lighting angles for a halogen/HID projector bowl to properly focus the light into a nice sharp cutoff, with good distance. All these things will do is glare like hell to oncoming traffic, and they will mostly flood the foreground of the car with light and not much in the distance(where you want light).
The new LED lamps have the actual LEDs in that very same position. And they have two LEDs on both sides of a narrow strip , covering as good as 360 degrees. As the Weisslicht mentioned above.
The older, 1st generation LEDs had LEDs all around, causing the glare that blinds opposite drivers.
I think/agree the H7 Halogen has its light emitting part at a fixed position, and headlight reflectors are designed in such a way that from that fixed position the light is projected in a most ideal manner to the street in front.
If LED is more efficient then it has to produce less heat for the same light output. With the heat produced in the front of the housing or less heat in the rear of it which is best, I cannot say myself.
You certainly want to keep them sealed away from moisture as they supposedly are now.
Which builds up the most heat during operation a regular H7 or the LED version? Our H7 bulbs are sealed in the housing, the heat produced is in the front of it.
on
Ditto, SS Ultra's for many years without replacement and super bright.
I guess someone is going to have to try them, to find out ...
on
Yes, filament bulbs of course. Anyone who knows anything about headlight bulbs know Sylvania Silver Stars are incandescent bulbs. If you hold them in your hands (by the base only, oils on the glass generate hotspots that reduce the life of the bulbs), you'll easily see the filament inside. If you go to any auto parts outlet and see bulbs packaged in blister packages, it is super easy to see which are LED or built as a standard lamp.
