Dead Pedal
Re: Dead Pedal
Later,
Re: Dead Pedal
I inquired this morning as to how wide the dead pedal was & vendor responded right away that is was 62 mm wide. Said that in RHD XFires in the "land down under", he removes the Velcro & adds double-sided tape for it to install properly. Let me know which version you get.
Later,
Later,
Re: Dead Pedal
There are multiple Mercedes (AMG) style dead pedals on ebay. I purchased the one that ships from Australia for $40.00. I feel it's the best match. Looks like OEM fit and finish. Other options range from $19.00 and up.
Mercedes AMG Dead Pedal Footrest A45 C63 CLA45 GLA45 W204 W164 X156 C117 | eBay
Check it out.
Check it out.
The first one was lost in the mail with just an empty envelope arriving. I should have taken that as an omen.
No big deal really, I just wanted it for looks, but others should be warned if you have to screw it into place or something.
It looks fine but its real tricky when it no sticky.
Re: Dead Pedal
Although I have not done it myself (with my dead pedal cover) I would suggest using velcro also. I plan to shave the carpet down (in a rectangular shape to match the velcro on the back of the pedal), then used carpet/headliner adhesive to attach a velco base for the pedal. I also thought about using a carpet/heavy duty sewing needle to tack some velcro on the carpet. You have options without using screws, which might ruin the look of the pedal.
TKD
TKD
Re: Dead Pedal
I found a Dead Pedal that matched the M-B pattern. Needed one wide enough to cover the mounting holes for the plastic version Chrysler installed in my 2007 XFire, along with the carpet cutout where the plastic dead pedal rested its bottom (new Dead Pedal covers at least most of it). And the Dead Pedal doesn't hang over the right edge. Dead Pedal came with a very tacky, double-sided tape on the back. But rather than use this to secure the Dead Pedal, I used a couple of industrial strength Velcro strips I bought from Amazon. I left the protective cover to the double-sided tape in place & just mounted the Velcro strips to it. Attached pictures show the final result. Looks fairly good; hope it holds up!
on
1 Post
Re: Dead Pedal
He recommends this one.
Stainless Steel Footrest to suit Chrysler Crossfire | eBay
Here's part of our conversation:
"There should be a listing on eBay.com (us site) for a footrest to suit the crossfire. It is essentially the same part however it features double sided tape instead of hook and loop tape. "
"It looks the same. Is it the same size? Personally I would prefer hook and loop attachment to the carpet rather than adhesive bonding to the carpet. Is there a reason to use adhesive on a Crossfire. "
" Yeah it's exactly the same apart from the tape.
Hook and loop tape doesn't work on the carpet in the crossfire (or any chrysler/jeep/fca vehicle as they all use 'Cut Pile" carpets in my experience), hence the adhesive. "
EDIT: I think the posters are talking to the same company. So what attachment works better on carpet?
Last edited by Kurtp13; 05-23-2017 at 06:27 PM. Reason: Clarification from later posts
Re: Dead Pedal
I wrote the seller and he sells the exact same part with an adhesive back for the Crossfire. He says that the velcro version will not stick on the Chrysler carpet. Seems like it works well for you.
The dead pedal I bought later was wide enough & came with double-sided tape for install. And if you look close, you'll see a small portion of a carpet opening at the bottom that still didn't get covered. But with floor mats placed in the footwell, it doesn't show.
Here's the link to the item I purchased.
Re: Dead Pedal
Even with the double-side adhesive tape, this dead pedal really doesn't fit my 2007 XFire. First - The dead pedal has a right angle bend on the pedal-side of the footwell. As a result, it won't fit flush against the carpeting. Second - My 2007 had the large plastic dead pedal provided by Chrysler. When this is removed, there are three large holes in the carpet that need to be covered (my opinion) to make the install look good. This dead pedal isn't wide enough to cover the holes completely.
The dead pedal I bought was wide enough & came with double-sided tape for install. And if you look close, you'll see a small portion of a carpet opening at the bottom that still didn't get covered. But with floor mats placed in the footwell, it doesn't show.
Here's the link to the I purchased. CLICK
Speedy4x4
73
04-15-2019 06:23 PM
davegray
04-01-2016 03:48 PM
