SKREEM question
Re: SKREEM question
Thank you everyone for all the information.
My wife's 2004 coupe has just started having trouble with the key fobs not opening the doors, or turning the alarm off. This happened after it had been parked outside for two weeks. There was quite a lot of rain during this time. The alarm is blinking and siren sounds when I open the door. I can get the alarm siren to stop by turning on the ignition and then turning it off. But the alarm light keeps blinking. The engine won't start. I have charged the battery and tried to resync the fob. But no change. I pulled fuse #9 and the alarm siren sounds when I pull the fuse.
Does this sound like a SKREEM or water related issue?
Thank you,
John and Terry
Thank you,
John and Terry
Re: SKREEM question
Look under the mat in the trunk and locate the foam block that fills the bottom of the right (passenger) side trunk well. you should see a deep cavity in the foam block. take a screwdriver and poke a hole through the bottom of the cavity. The foam is only about 3/8 inch thick, and it is the lowest part of the trunk. Enlarge the hole with the screwdriver just to be sure water can seep through. If water percolates up through the hole you have a problem.
Re: SKREEM question
Re: SKREEM question
John & Terry,
Still working on my diagnosis from the issues you described which started this thread for me... however, still also driving my 2005 coupe in the meantime with Fuse #9 removed, I know, some say I'm asking for trouble but if I didn't have a way to work I'd be asking for more trouble in the form of a pink slip
You'll need to disconnect the battery, then remove the fuse, the reconnect the battery for the alarm not to sound when you remove it. Hope this helps and 5 days in, just to update, still no adverse effects with the fuse out and driving normally, other than getting lots of stretching exercises forgetting to lock my passenger door before getting out and having to reach back in to do so before using the key to lock my driver's door... maybe that's a good side effect...I'm now doing Yoga and not having to pay an instructor...
stay tuned...
stay tuned...
Re: SKREEM question
They are not normally there, but as you can see I was working on the car at the time. I cannot remember what exactly I was doing but the putty knife lifts the pin in the centre of the trim retainers and the pliers are used to grab the pin and pull it out. I have a plastic tool for that now.
Re: SKREEM question
Re: SKREEM question
Makes perfect sense to me. Needle nose pliers is what I used in the past to remove those pins. Only difference was I used a thin bladed screwdriver to lift the pin slightly until I could get the pliers underneath to lift/pry. And like you, I also have a plastic pin removal tool for this now.
Re: SKREEM question
Hey, just an update... so still have not revisited the original issue which I am still pretty sure is the SKREEM module in my vehicle but just wanted to provide a real use update on my work around "remove fuse #9" fix.
Still driving my car, no issues. Granted, like I mentioned in a number of my previous posts, I have to manually lock my doors and the security feature is disabled without this fuse in but I do have my car to drive on a daily basis and have even taken it twice on long (5 hr one way trips) with no issues.
Just wanted to follow up. I will at some point invest in having this resolved but for anyone searching the boards with this all to common issue.... just letting you know this is out there as a semi-long term work around...
Thanks!!!!
Thanks!!!!
Re: SKREEM question
Thanks!!!!
Thanks!!!!
Thank you for that. I still have no idea about the cause or the likelihood of "Skeem" failure/malfunction.
Re: SKREEM question
Update: Just logging in to update anyone who is interested... I've had this 'work around' in place now since the beginning of the year (removing Fuse #9) and again, other than the side effects (no interior light (I don't really drive at night), old school key use manually locking/unlocking doors, and no alarm)... my Crossfire continues to get me to and from anywhere I've needed to go. I'm sure at some point I'll suck it up and have the SKREEM replaced but if you are in the same boat I was (not really wanting to be without my vehicle, no tried and trusted mechanics in area to perform work, and didn't want to come off a few hundred to get it done when it occurred) just know... you have this option (I guess now ... long term if you need it).
Good luck!
Good luck!
redsnake (03-31-2021)
Re: SKREEM question
Anyway I think the problem lies in the CLP/SSM and not the SKREEM. Fuse #9 is for the siren and a few other items as outlined previously. If getting around the SKREEM was that easy there would be more Crossfires stolen.
Re: SKREEM question
I think that the poster is a gal not a guy at least it was at the start of the thread. Maybe a sex change?
Re: SKREEM question
Thanks so much for posting about fuse #9! It works!!! The Mercedes mechanic did it for us, he said it had to cycle through a few times, but after disconnecting the battery, removing fuse #9, he got it going. Running great now.
okay, so just happened upon the SKREEM threads and luckily upon the 'remove fuse #9 remedy" to keep me from having to tow it home (although not sure how I would have even gotten a tow out of the parking garage I was parked in at the time... anyway)... CF is home in my garage now without Fuse #9 in place.
Question is... if I am not concerned with my alarm system (siren has been turned off since I bought it 4 yrs ago anyway), the key fob functioning (will just deal with unlocking it manually) or the interior lights (not that functional or bright anyway and always have my phone which I can light whatever I need to see if it's dark out)... what is the harm in simply leaving Fuse #9 out permanently so I don't have to deal with the replacement of the SKREEM module? (Or trying to find a technician who has experience with a Crossfire). Any downsides other than those I've mentioned???
Thanks for potentially developing a work around to having to inform my husband that we need to take my baby to a dealership and drop a sizable check to keep me happy.
Thanks for any insight.
