Who Did And Didn't
Who Did And Didn't
Who did and who didn't install rear camber kits when lowering your car with just springs, like the Eibach Pro Kit? I'm not getting much info. on the post I made in the SRT6 section, I've finally found the rear camber kit, but it's as much as the springs were. I just need to know how bad the tires are going to lean in and wear if I don't buy the adjustable rear camber kit. I'm guessing that the dealership will be able to straighten up the front pretty close to where it needs to be.
Thanks in advance to anyone who responds,
Steve
Steve
Re: Who Did And Didn't
Sorry I don't have the exact answer you're looking for, but please realize that having negative camber is not necessarily an evil thing. In fact, in the right doses, it can be a very good thing. Also, toe eats up tires worse than camber does. A couple degrees of camber with zero toe shouldn't really be a big deal for tire wear.
I did not install the camber kit. I have used the Eibach pro kit on many cars over the years and have not had a problem with tire wear on one edge or the other. I didn't feel the need to get the kit for the x-fire either. I think the more you lower a car, the more the camber is affected.
Now, if I dropped the car 3 inches or more, I would definitely get a camber kit to toe out.
Mike
Mike
Mike
Mike
Thanks,
Steve
Originally Posted by Steve Hellums
Did you have a front alignment done? And the same question I asked Mike, from the rear view of the car can you tell that the top of the tires are leaning in?
it was still in aligned once lowered... no adjustments could be made via the alignment company when i took it in. they only charged me to check it (tracks perfect with no wear front or rear).
and you are correct negative camber indeed in the rear... but no inner wear of the tires.
hope this helps.
Originally Posted by andrew
i did attempt to have an alignment completed but...
hope this helps.
hope this helps.
The front does look straight up & down in the pictures.
Oh and I think I see a speck on the left side of your rear bumper.
~ you spotted it... indeed dusty - dirty... about a week of dry road dirt.
~ the front really has no negative camber... just the rear.
Steve
Originally Posted by AMGLover
Dude call Eibach and find out what are the spring rates! Hey I want you to be safe, and since you are one of the few guys here who get your crossfire over 150 mph the modification your drive train has greater impact then the other pavement princesses who never get it past 90 mph. Oh and you have had a bad run in with a pole...
The SRT-6 Coupe and Roadster models are tuned differently, to their own unique characteristics. The Coupe's spring rates are 451 lb./in. in the front and 480 lb./in. in the rear, while the Roadster's are 434 lb./in. in the front and 451 lb./in. in the rear. So you may over spring the car which may cause you to loose down force or in the worst case loose contact with the pavement – really bad thing at 160 mph.
Only simple linear springs have a spring rate. A sophisticated progressive Eibach Pro-Kit spring has a load/deflection characteristic. The special design parameters are only accessible through Eibach Desk-Tech Database to Eibach's exclusive partners.
And:
All Eibach Pro-Kits are designed for the same maximum load like the OE springs. Actually, a progressive Eibach spring generates higher resistance under heavier load.WA
What is the spring rate of the Pro-Kit?
A
Originally Posted by GatorLCA
I have another question for the "Who did and who didn't"
Did you replace the stock shocks??
Reason being, I don't feel like plunking down $300 + labor on Koni's if I don't really have to
hope this helps.
hope this helps.
