Car Not Unlocking 5% Of The Time
Old Jun 29, 2014 | 04:31 AM
eseb1's Avatar
Question Car Not Unlocking 5% Of The Time
Anyone have issues with the car not unlocking via remote? Once every two weeks or so it refuses to and I have to insert the key into the door handle to unlock the car. I replaced the car battery 2 months ago and just recently replaced the key batteries and the problem persists.
Thanks
Old Jun 29, 2014 | 08:12 AM
Default Re: Car Not Unlocking 5% Of The Time
Thanks
Read this thread.
Old Jun 29, 2014 | 04:27 PM
eseb1's Avatar
Some more info: The car will unlock when I insert the key into the door, so that rules out the pump mentioned? The key, none of the buttons will work, so that rules out the contacts being worn out? The key, once the car is unlocked via the door handle, all of the buttons work immediately, so that rules out the battery not getting proper contact?
So this seems to be something else.
Old Jun 29, 2014 | 05:27 PM
I'd hazard a guess and say that the problem is in the radio signal from the fob somehow.
How many fobs do you have? Do you have trouble with both if you have two?
Old Jun 29, 2014 | 05:32 PM
eseb1's Avatar
Only have one right now, unfortunately.
Old Jun 30, 2014 | 05:01 PM
Adrian_X's Avatar
Hey bro, try to re-pair the key remote to the car real quick and let me know if it still does it.
The pairing process is pretty simple.
1. Insert key into ignition.
2. double press either the lock or unlock buttons.
3. Turn the key in the ignition to the ON/RUN position within 30 seconds of pressing either button.
Old Jun 30, 2014 | 05:30 PM
That's not what the Owners manual says, but I'm not sure it matters either way.
The 2004 manual says the following.
The system may have to be resynchronized if the transmitter
is without voltage for several minutes. To synchronize,
aim the transmitter eye at the vehicle and briefly
press either the Lock or the Unlock button twice. Within
approximately 30 seconds, insert the key in the ignition
and turn it to the ON/RUN position. The remote control
should once again be operational.
Old Jun 30, 2014 | 06:59 PM
6 of one, half dozen of the other.
The 'eye' does nothing, it is an RF transmitter, not an IR transmitter.
In Adrain_x's example, the remote is just a bit closer than in yours.
Old Jun 30, 2014 | 07:10 PM
Adrian_X's Avatar
Regardless of how he does it, trying it can't hurt. Another member on the Chrysler Crossfire facebook group had a similar issue where the key wouldn't unlock at all even while used in the door. After I had her reprogram the key, it worked flawlessly. This might help him out lol
EDIT: btw ala, been considering upgrading my 5 sided T10 eyebrow LEDs to what you have in right now(the 25watt ones). Yay, nay? Do you have any pics of them by any chance?
Old Jun 30, 2014 | 09:20 PM
eseb1's Avatar
Alright, have done so, will see if this solves it, normally happens once a week, unlocking the car at least 20 times each week, will hopefully know within 2 weeks if it did solve the weird issue. Thanks.
Side note, might have been important to note: Yesterday it happened again and I noticed that once I turn the car on, both blinkers flash once. Not sure why, that might be important or not.
Old Jun 30, 2014 | 09:48 PM
Adrian_X's Avatar
Double check the terminals on the car battery, and see if there's any corrosion on them just to be sure. If one of the terminals isn't making proper contact that could do it too.
There's also the issue of having a loose ground somewhere in the engine bay that could be causing it?
Old Jul 2, 2014 | 11:30 AM
AlG's Avatar
AlG
I have this problem too. Happens about 50% of the time. So, I use the key, big deal. Somewhere the fob isn't linking with the car. It's not something I worry about.
Old Jul 2, 2014 | 05:20 PM
eseb1's Avatar
Alright, well thanks, I guess. I worry about it.
Terminals on battery are fine on both, it's not a power issue as the car unlocks fine with the key, and the key works instantly once manually unlocking.
Hasn't happened again yet, hope the key reset worked for whatever reason.
kjwinston
Jul 7, 2015 04:04 PM
autumnmass
Jul 2, 2015 10:35 PM
cojoman
May 30, 2015 09:43 AM
Rwright2
Sep 18, 2003 04:55 PM
mouserider
Jul 26, 2003 11:47 PM
