No start, situation
Old Aug 3, 2018 | 01:26 PM
djohn14296's Avatar
Unhappy No start, situation
Went out to start my Xfire this morning, got in depressed the clutch and turn the key to start, and nothing. All the normal idiot lights come on as normal, but nothing. If the key was left in the run position, the fan would start run, which I found unusual, never notice before if it did that? But I assume that, being electrical that it would only come when needed, and this was the 1st start in 2 days. Run and started fin 2 days ago. Any suggestions, if I can't fix it, then my only choose is to have it tow to a Chrysler stealership. Lots $$$$, then. Can a standard transmission Xfire be push started? Any help, suggestion welcome.
Old Aug 3, 2018 | 01:49 PM
Default Re: No start, situation
replied to your PM ( RCM )
Old Aug 3, 2018 | 02:35 PM
Yup, no starter engagement with a "Warp speed fan" means the engine control relay's output on the RCM is bad -either fractured solder on the RCM or bad relay on the RCM.
It's usually the solder, not the relay.
Old Aug 4, 2018 | 10:33 AM
tighed1's Avatar
As mentioned, it's the relay control module.
Email me for repair information tighed1@hotmail.com
Old Aug 4, 2018 | 11:01 AM
djohn14296's Avatar
BTW got no response from tighed1, either phone or email. But for now problem solved. thank you all pointing me in the right direction. $35, a little time, cheap at twice the price. But I'm take my solder gun and solder with me just in case, I'm not the best solder in the world, but it works that is all I care. Again, a shout out to Pizza Guy, George and Dave for their help and suggestions.
Old Aug 4, 2018 | 11:34 AM
You can always purchase and carry a spare !!
Old Aug 4, 2018 | 12:17 PM
djohn14296's Avatar
Thumbs up Re: No start, situation
I assume you're referring to the RCM? Might you know where one can be purchased?
Old Aug 4, 2018 | 12:45 PM
I got my used one for $45 way back on eBay CLICK
There are cheaper places than this though some new ones for $120 to $140.
Search the forum for places to buy them.
Old Aug 15, 2018 | 03:25 PM
UrbanE's Avatar
looking for advice suggestions
no start yesterday and again today.
Its not the RCM. I’ve just soldered up the three connection points that are the culprit and the fan does not turn on when attempting to turn it over
yesyetday it started after sitting. And it started again today
cluld it be starter or have I missed something on the RCM
My guess is starter it turns over twice but dies before it actually starts. Any suggestions or test procedures to narrow it down would be appreciated
Old Aug 17, 2018 | 12:17 PM
Cobrasrt8's Avatar
i had the same issue with one of mine.so I soldered the rcm and still same problem. So I switched the rcm from my other crossfire and it worked perfectly. It may be something internal with the rcm.
I had continuity between all 3 contacts so somehow they were touching somewhere. Which wouldn't let me access the ecm and couldn't get it out of park. It would give me a p0600 code. Purchased a new one from rock auto. I'm still going to send the other one to tighed1 so I have a spare.
Old Aug 17, 2018 | 05:01 PM
The contacts on the RCM can also go bad. TIGHED1 can do the complete rebuild. Send him a PM.
Old Aug 17, 2018 | 06:01 PM
tighed1's Avatar
Email me tighed1@hotmail.com for rebuild info!
Old Aug 18, 2018 | 09:06 AM
Ed Mahoney's Avatar
If you need it fixed , tighed1 is the answer ! Saved me ! Can’t thank him enough !
Old Aug 18, 2018 | 09:53 AM
My guess is that it senses something is not giving the correct feedback so it quits, normally if it turns over then it is not the RCM.
Can you hear the fuel pumps when you turn the key to the 1st position?
What about the crankshaft and camshaft position sensors they could cause trouble. Also study the relays in the RCM when they key is turned do the fuel and BCM relays move? Is there any signs of sparking damage on the relay contacts?
AllEuro
May 24, 2010 03:36 PM
midlife chrysler
Mar 24, 2010 02:03 PM
dragon
Feb 21, 2010 11:12 AM
04matthew
May 8, 2009 10:29 PM
rcaw
Jun 5, 2007 04:12 PM
