Does anyone know the part number for this item?
Old Dec 16, 2018 | 09:54 PM
bionicdriver's Avatar
Default Does anyone know the part number for this item?
The interior door handle has broken and I need to find this particular part. Im not sure if its a Lear or Trager part anyone have any ideas?
What is the black part called and what part number is that?
Old Dec 17, 2018 | 08:53 AM
zip439's Avatar
Default Re: Does anyone know the part number for this item?
Try this:
170-760-04-62-7E8 bezel, there are right and left ones. You may find the Mercedes number on the back side. I found it it in the lock and hardware category. Probably better to find one at a local junk yard. The silver handle part is a different number than the black bezel.
Are you sure the cable has not come undone, or fallen out of it's brackets as it leads aft towards the outer door handle? That is not unusual.
Old Dec 17, 2018 | 10:01 AM
Originally Posted by zip439
Try this:170-760-04-62-7E8 bezel, there are right and left ones. You may find the Mercedes number on the back side. I found it it in the lock and hardware category. Probably better to find one at a local junk yard. The silver handle part is a different number than the black bezel.
That number is wrong according to my records, a bezel is a trim piece and on the Crossfire the passenger side part # is A193 760 01 20, driver side would be A193 760 02 20.
The OP shows the inner part called a 'recess' in the SLK parts manual and the LH part# is A170 760 02 62, RH part# is A 170 760 01 20.
The LH handle is part# A202 766 01 24, RH part# is A202 766 02 24. I'll double check all these numbers as there is a mix of Crossfire and SLK part numbers as well as the 202 model number series.
The OPs photo shows the part rotated 180 degrees.
As stated in the previous post maybe the cable has come loose or broken. as that is what it looks like with the cable unattached, the handle just sags.
Old Dec 18, 2018 | 07:03 AM
I apologize for not rotating that picture, the cable is loose but my mechanic said i need another "recess". Thanks for the name and part number guys
Old Dec 18, 2018 | 07:16 AM
Im not sure if the cable has come undone. How do I check is there a link for the door handle assembly?
Old Dec 18, 2018 | 07:57 AM
zip439's Avatar
To check Cable, you remove door panel. Follow the link in 180's signature "Index of Crossfire problems, repairs and How to's". You will find a write up of how to do it.
I wouldn't believe your mechanic, because if he has not removed that door panel he does not know either!
Old Dec 18, 2018 | 12:41 PM
If you need the part go to a wreckers yard, get the recess and the handle assembly, I think the cable is probably broken though.
The only way to find out is by removing the door panel.
Old Dec 19, 2018 | 01:38 AM
Thanks I'll try the cable and go from there... I'll post my result this weekend. I have to order the cable any chance you know which part number the cable is!?
Masterwarren
Oct 3, 2018 07:01 PM
tje275
Aug 15, 2012 10:22 PM
samer2thamer
Dec 22, 2009 05:53 PM
Isellthem
Sep 16, 2008 04:58 PM
