Locked out
Old Mar 2, 2020 | 09:05 AM
g wheels's Avatar
Default Re: Locked out
Originally Posted by Valk
Believe what you wish but when Rudy our very own Crossfire expert and V8 conversion guy who is foreman and chief mechanic of a prestigious Mercedes Benz dealer in the north suburbs of Chicago tells me this I have NO doubt its true
Hey, thank you for verifying!
As soon as I'm done looking through the new posts; I'm going for my one and only key fob, pressing the BIG button while shouting out "lock er up.."
Old Apr 16, 2020 | 10:24 AM
g wheels's Avatar
Wanting to verify that my crossfire does indeed draw less power when the car is locked up, I did a parasitic voltage draw with the car locked and unlocked. Both tests were performed with a volt meter attached between the battery and the disconnected negative battery cable. After 25 minutes, both conditions produced a settled and stable 2.7 voltage draw. It's an easy test. I kept my ECU memory intact with a tool that supplies 9 volts via the DCL port..
Old Apr 16, 2020 | 02:39 PM
ambidextrous's Avatar
Is that a 2.7 milliampere currentdraw?
Old Apr 16, 2020 | 03:15 PM
Probably 27 MA, which is about normal.
Old Apr 16, 2020 | 03:55 PM
Or, he connected the meter as a voltmeter and the reading is meaningless.
Old Apr 17, 2020 | 08:29 AM
I lock mine every time I exit the vehicle
Ditto this with ours!
Old Apr 25, 2020 | 02:03 PM
g wheels's Avatar
You are correct. I just got in from re-testing and whether the car is locked or not I get 28 - 26.5 mA.
I will be honest about the initial post. It was volts and when asked if my reading was milliamperes I realized that my first finding wasn't useful.
Thanks..
Old Apr 27, 2022 | 12:28 PM
Goldenthrone's Avatar
Originally Posted by ttmmdd
You can open the hatch without a key by removing the driver's side license plate light and poking toward the latch with a stiff wire. There's a more detailed description someplace on this forum. I know this works because I did it once for practice.
So true!!! I just did it and got in my car in less than 10 minutes. I had to play with the handle at the same time and walaaa! Thank for the info
RogerO
Jun 25, 2021 01:51 AM
Goldwing
Jun 23, 2014 01:19 PM
MikeG
Feb 21, 2014 04:41 PM
xfirebama2333
Aug 3, 2007 01:24 AM
AZ Outlaws
Jan 1, 2004 01:35 PM
