Still won't staft9
Old Jun 15, 2020 | 03:07 AM
Gclcjc's Avatar
Default Still won't staft9
Still want start changed brake switch changed crank sensor and cam and rcm and it still won't start also stuck in park . And spoiler is stuck in up position.
Old Jun 15, 2020 | 07:48 AM
Fla_Xfire_SRT's Avatar
Default Re: Still won't staft9
~ Wing up usually means bad battery....bad battery usually means faulty charging system.
~ Inspect the Transmission harness connector for "O"-ring leakage.....If found..
~ Lift the carpet in the passenger footwell and unbolt the cover that houses the TCU and inspect for signs of fluid wicking....Replace the transmission harness connector adaptor...($12.00 or so)..
~ Stuck in park may be a result of a spill into the shift selector module...
~ If you decide to replace the shift selector module, study the video on "ash tray fix" to learn how to disassemble the center console....expect 15 yr old brittle plastic clips to break.
Old Jun 15, 2020 | 09:43 AM
Why start another thread, all the previous ideas that did not work will be written out again.
A new thread leads to confusion and duplication and some will not bother to answer at all.
Does it come out of park if you put your foot on the brake?
I would study the posts on the RCM and how the relays work when trying to start the car.
Old Jun 15, 2020 | 10:27 AM
Gclcjc's Avatar
No it wont come out of park with foot on brake
Old Jun 15, 2020 | 10:29 AM
Gclcjc's Avatar
The battery has been checked aswell and it's all ok.
thegreatjustino
38
May 12, 2019 08:30 AM
TopJimmy
Aug 7, 2017 09:16 PM
fnewendaiku
Jan 4, 2015 06:10 PM
only1jt
Nov 10, 2003 01:08 PM
kusheen
Oct 26, 2003 08:22 AM
