Stumble, stall?
Old Feb 13, 2021 | 05:25 PM
No704's Avatar
Default Stumble, stall?
2005 was just driving around my neighborhood and stoped at a light. Engine stumbles and stalled. Fired right up with turning the key 🔐 off and back to start.
wth? Any ideas?
Old Feb 13, 2021 | 05:30 PM
Default Re: Stumble, stall?
A common cause for this is a bad Crank Position Sensor. Of course, it can be a dirty MAF sensor or a lot of other things, but if you have not replaced the CPS recently, I'd order one from German Auto Supply, Needswings, etc. Do not purchase locally. You want to search "Crank Position Sensor, 2003 SLK320"; OEM Bosch parts only.
Old Feb 13, 2021 | 07:07 PM
What he said, BOSCH PARTS ONLY. Too many times (documented here) aftermarket parts sometimes do not connect or work properly.
Last edited by GraphiteGhost; Feb 14, 2021 at 11:10 AM. Reason: Added 'sometimes'...
Old Feb 14, 2021 | 12:39 AM
JSK's Avatar
JSK
If you are in Tempe you can get a Bosch from Auto Haus AZ in Tempe.
Old Feb 14, 2021 | 01:23 PM
No704's Avatar
Thanks for the input. Yes in Tempe.
Old Feb 15, 2021 | 04:28 PM
No704's Avatar
Would this have stored a cel code?
Old Feb 15, 2021 | 05:01 PM
The crank sensor often sets a code and the CEL will come on. But this is not always the case, it seems that the crank sensor can fail such that the ECU knows it has failed and sets a code.
Other times, the CPS fails such that the ECU can't run the engine, but it also cant tell why it can't run the engine.
Sorry, but there is no definitive answer to your question.
Old Feb 15, 2021 | 07:10 PM
Wrong PG, the definitive answer is "maybe" or "sometimes"
davezipter
Nov 29, 2020 03:36 PM
tropixcale
Jul 19, 2016 03:42 PM
Bayukbros
May 6, 2016 10:52 AM
TOPLA
Jul 14, 2015 07:46 AM
orefin
Jun 28, 2014 11:15 AM
