Buy a Crossfire?
eelya1 (01-08-2023)
Re: Buy a Crossfire?
The problem is that i'm not 'handy at all, so if they tend to have issues it might not be the car for me.
eelya1 (12-08-2022)
eelya1 (12-08-2022)
Good advice to look around the Forum to see what issues Owners are dealing with. Many nuisance versions can be corrected with minimal automotive repair skills if you follow the recommendations & procedures previous owners have listed on the Forum. For any significant issue that comes up, you just need to locate a reputable Mercedes independent repair facility in the Charlotte metro area. There is a thread on the Forum that lists service shops recommended by Owners. You need to search for it. You can also use this website to locate reputable M-B independent service shops in Charlotte area: CLICK. These service shops should be able to handle any issue that surfaces regarding the power train, rolling chassis & many of the electrical issues since the Crossfire is a M-B SLK 320 of the first iteration (R170 chassis) but with a better looking body designed by Chrysler.
The following 2 users liked this post by dedwards0323:
eelya1 (12-08-2022),
exparamedic (12-04-2022)
This link will give you more insight for choosing a Crossfire.
https://www.crossfireforum.org/forum...-what-not.html
eelya1 (12-08-2022)
As with any car that is 14 to 18 years old you will have issues. I have an 07 roadster 49k which I've owned for 5 years bought it with 28k no problems except rear convertible window coming unglued which is a common problem. Buy from someone who has taken good care of the car. The condition will tell you a lot. I've got a lot of enjoyment and pride driving, owning and working on my Crossfire. You are more capable of working on a car than you think, push the boundaries and grow
eelya1 (12-08-2022)
on
No one buys a Crossfire, you adopt a Crossfire. When issues arise, it is up to you to get them fixed, as there is no factory support for this car - therefore, when you take the car to a Chrysler dealer, nothing good happens. The ONLY factory support is for the federal airbag fix - it can still be very costly for this 'free' repair, but at least there is limited factory support for this. It's just that the dealer will keep the car if they can't get the airbag module to respond after the fix, (for your safety, of course, so don't get mad about the additional costs and delays-you were the fool who went to a dealer) and you are liable for the costs of the additional repair.
If you are a member here or on one of the facebook pages, there is help for any issue that arises. The volume of knowledge here is extensive.
My warning, once you get past all the common checks (looking for leaking fluids, how does it start and run, etc.) is that when you bring it home you:
- Order an RCM and learn how easy it is to change it (no tools needed, ANYONE can change it) and learn the symptoms that tell you the RCM has failed.
- Order a BOSCH Crank position sensor and put it in the trunk.
- Check the battery, is it over 48 months old? If so, replace it and do that every 48 months. Put in one of the simple ground fixes in this thread (cost is an hour of labor and $25 for parts)
- Take the oil filter carrier out and verify that the filter is a Fleece and not paper filter.
- If it is a convertible (Roadster) exercise the top every three weeks but not below 35F.
- Avoid dealers.
- Do not take the car to a dealer for anything other than TPMS resetting.
- Stay away from dealers.
- Remember that dealers won't help you.
- Dont even hire a tow truck operated by a dealer.
The following 3 users liked this post by pizzaguy:
My experience, only. The Crossfire is not a turn key & drive automobile. The car is not a Mercedes Benz, the car is not a Chrysler. In my opinion it's the best and the worst of both worlds. If you want to own a Crossfire be prepared to deal with whatever issue at whatever cost. I drive mine approximately 3 to 500mi almost every weekend and the care and feeding has been substantial. If I had not found who I would consider one of the best mechanics in South Fl, if not anywhere, I would have had to part ways with my pride & joy 6 months after I purchased it. Before I would even consider purchasing one of these cars I would first find an available first class mechanic who knows everything about this crossbreed & how to repair it at a more or less reasonable cost. I find the only difference between owning a pet and owning a Crossfire - you can leave a Crossfire locked up for more than a week and when you get home it's no worse for wear & ready to go.
The following 3 users liked this post by batmanmiami1:
eelya1 (01-08-2023)
on
I totally agree with batmanmiami1.
I would like to add that my friend is an excellent mechanic but not a Mercedes mechanic. In his home shop, we have been able to fix anything that came up. I have also been able to do a lot of repairs in my own garage.
BUT....
We have only been able to do this because of this forum. I have a binder full of things that I have printed from this forum and put to use in the garage.
The diagnostic guides, instructions, videos, pictures, diagrams are all beyond priceless. Bonus when part numbers, sockets and screwdriver sizes, and torque settings are included.
A huge thank you to all who have contributed their expertise and guidance on this forum.
I am truly grateful.
Would I buy a Crossfire again? Yes. But then I had a Fiero for 27 years and was used to this kind of relationship.
Thanks again
Jim
BUT....
Thanks again
Jim
eelya1 (01-08-2023)
on
Speaking of belts....
Way way back I had a Corvair. Loved it but it ate belts with the 90 degree direction change over the top of the engine and then down. Got pretty good at changing them.
Then a Fiat 850 Spider convertible which was surprisingly reliable and took everything that I dished out.
Nightmare experience with a 1976 MGB which was only a year old and under 20,000 miles when I bought it. Everything went wrong with that car.
Fiero was a breath of fresh air after that MGB.
Someone once said that some parts of a vehicle were designed and engineered by true craftsmen. Other parts were by Moe, Larry, and Curly Joe.
Jim
Jim
eelya1 (01-08-2023)
I kind of disagree that it is not "turn key and drive". I bought my roadster new and the only issues were the fan recall and a slipped transmission shift cable. Otherwise trouble-free for 65k miles. Bought the SRT6 in 2008 with 16.5k miles and only problems were the supercharger pump (fixed under warranty using documentation from this forum) and then a popped plenum plug. Currently at 42k miles. Both vehicles serviced by an indie shop that specializes in European metal. Also both stored during the Michigan winters, so only driven 7-8 months/year.
eelya1 (01-08-2023)
I have had two Crossfires, one brand new NA that I drove for 24,000 miles in six years and an SRT that I have driven for 25,000 miles in eleven years. No trouble at all except I thought the brake pedal was too low, it’s up a bit now. Then I had an air filter on the NeedsWings CAI that disintegrated and a part got jammed in the throttle. It disintegrated because I had got it with as a spare when I purchased the car and fitted it when I cleaned the original one. I found the instructions for it a year later and they said not to oil it, but I had. Oops, dodged a bullet there. No other troubles so I cannot complain.
We have more problems reported now because the cars are older and in many cases have been neglected and abused. The reason people sold the car was because it was having too many problems.
eelya1 (01-08-2023)
on
- Avoid dealers.
And as to expensive repairs, Robert McCubbin changed my fuel filter/pump in his driveway. My Ford Ranger was a mess, had to drop the tank - total cost with tow was almost $1100.
NOTHING on the Crossfire costs that much, altho tires come close. (The new top was under $750.)
eelya1 (12-28-2022)
Buy one that has been stored in the winters if it is from the rust belt and look under the fender lips for rust. Buy one that is low mileage and has been maintained correctly and not thrashed everywhere it went, look under the hood and put it on a hoist to look underneath.
Look for one with few owners, as too many owners points to people unloading a lemon.
eelya1 (01-08-2023)
Find someone who can help you do a used car inspection. Looking for obvious things like corrosion, leaks, worn or damaged suspension components, etc. Drive it and make sure YOU fit the car and not the other way around. Specialty cars have a certain way of communicating with potential owners and you want to make sure YOU can adapt to the cars quirks and issues. As stated above, spare key is great as is any kind of service history. If you buy one, get a spare RCM and crank sensor and throw them in the trunk for a rainy day. Speaking of rain, make sure there's no rain on the passenger side floorboard.
The following 2 users liked this post by xfClifford:
CROSSFIRERUSH (01-17-2023),
eelya1 (01-08-2023)
