Automatic Transmission Dipstick ???
Old May 26, 2006 | 02:12 PM
VQ35DE's Avatar
Default Automatic Transmission Dipstick ???
Is there a dipstick to measure the ATF? If not, how do you know how much is needed or maybe it's too full? Just wondered how the level is checked. Anyone know?
Old May 26, 2006 | 03:02 PM
figitt's Avatar
Default Re: Automatic Transmission Dipstick ???
It has a break away security cap... you will need to have a new cap for the dipstick tube, and you will also need the special tool (long dipstick with correct measurements) #xyz. The procedure is to obtain the transmission internal temperature via test box using the on board computer, and apply that temp to the chart in the manual, and then set level accordingly. When your done, cap it with the break-away cap.
Note: The special dipstick is longer than the tube... and goes all the way in and stops on the pan of the transmission, measuring from there.
Also, the transmission uses very specific oil...
Old May 26, 2006 | 04:59 PM
VQ35DE's Avatar
Can any of our Tech or Parts members (Danno) please post the TSB that covers the ATF leak and replacing of the 2 O-rings? Thanks.
Old May 27, 2006 | 09:50 AM
CrossfireLTD's Avatar
Cool Re: Automatic Transmission Dipstick ???
Here ya go.
https://www.crossfireforum.org/forum...light=tsb+list
Old May 27, 2006 | 10:02 AM
ben47's Avatar
O/T: Find TSB's here:
http://www-odi.nhtsa.dot.gov/cars/pr...aintsearch.cfm
syfi
Mar 28, 2026 04:14 PM
Oct 1, 2015 01:42 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
rfourt
Sep 25, 2015 01:38 PM
atdavis2
Sep 21, 2015 01:25 PM
