How do you turn the Speed Limiter off on an SRT6
Old Jan 23, 2008 | 05:59 PM
truecarolinablue51's Avatar
Default How do you turn the Speed Limiter off on an SRT6
I want to see just how fast my SRT6 will run. How do you turn the Top speed limiter off. I have topped out at 161 and I feel it will go a lot faster. Please help. I want to make it FLY!
Old Jan 23, 2008 | 06:08 PM
RPM's Avatar
RPM
Moderator
Default Re: How do you turn the Speed Limiter off on an SRT6
You don't.
You have to get the ECU re-programmed to remove the speed limiter.
Old Jan 23, 2008 | 06:20 PM
BrianBrave's Avatar
<--- Huge Horsepower
Originally Posted by RPM
You don't. You have to get the ECU re-programmed to remove the speed limiter.
FYI - You can't actually have the speed limiter "Removed" only raised to 200MPH - there must be some digits programmed in the ECU and 200MPH is the max. That's fast enough for me (or at least for my tires)
Might as well have the RPM limiter raised at the same time.
BTW - the factory setting on the speed limiter is 155MPH
Old Jan 23, 2008 | 06:55 PM
Sidez's Avatar
wouldn't it be tranimission limited at much lower speed than 200?
Old Jan 24, 2008 | 08:29 PM
HDDP's Avatar
Wow, your speedo must be really messed-up...
Old Jan 24, 2008 | 08:48 PM
Jeep2Xfire's Avatar
If it can be made by man, then it can be unmade by man. Just a matter of time before someonenot of MB/Bosch/etc. cracks the machine code...
Old Jan 25, 2008 | 07:31 PM
Default Who can set the speed limiter?
Who can you send your ECU to to have the speed limiter set? How much does it cost and does it affect the warranty if I take my car in for service? Thanks for the info!
Old Jan 29, 2008 | 09:43 AM
Texpar's Avatar
Default Re: Who can set the speed limiter?
how can the transmission possibly limit it??
Old Jan 29, 2008 | 10:23 AM
Who can you send the ECU to and have the speed limiter raised and RPM limiter as well?
Old Jan 29, 2008 | 10:30 AM
RPM's Avatar
RPM
Moderator
Renntech, Evosport, SpeedInnovations, and some others.
Old Jan 29, 2008 | 02:21 PM
BlUEMDsrt6's Avatar
Tou can try Inmotion too (they're probably cheapest of the bunch too).
Old Jan 29, 2008 | 06:56 PM
mousegu's Avatar
maybe he meant in the last gear with the RPMs at readline it would be below 200mph? so the transmission is limiting it by not having another gear? i dunno jsut guessing
Kodebuster
Nov 5, 2020 04:06 PM
amx1397
Jan 24, 2016 02:12 PM
JEFASOLD
Jul 15, 2015 02:32 PM
Rusty475
Jul 13, 2015 10:03 AM
GWAPA
Jul 8, 2015 07:25 PM
