My first oil change...
Old Jun 27, 2008 | 10:00 AM
Default My first oil change...
Recently purhasing my '04 Coupe with no written history report from the owner, I figured it was time for the oil change. I have used NAPA oil and filters in our fleet cars for years with no problems. With that in mind, I purchased a NAPA oil filter. After some comparisions, I am not sure that was a good idea.
Can anyone tell if this is the original oil filter?
Old Jun 27, 2008 | 10:03 AM
Default Re: My first oil change...
Once I got the belly pan off, the plug was very easy to get to.
I happened to have the perfect fit wrench in my toolbox for the filter housing.
I added 8 qts of oil.
Did you notice you can't get a funnel down in the fill tube real good. That is a PIA to hold the funnel the whole time.
Old Jun 27, 2008 | 10:05 AM
Is this the proper level after adding 8 qts of oil?
Also has anyone left the belly pan off to get rid of more engine heat while going down the road?
Do you think I should change out the oil filter for a different one? What and where?
Thanks, James
Old Jun 27, 2008 | 08:40 PM
Since I have no track record of oil changes, I plan to change it again at 3000 miles. What are your opinions of oil change intravals after that?
I am just a 'blue collar' worker, so $60 oil changes will only be done when recommended, not before!
Thanks, James
Old Jun 28, 2008 | 12:59 AM
Mimi05SRT6's Avatar
Thanks, James
I left my belly pan off too thinking more air will get under the hood to benefit my open intake. What do others think?
I did my first oil change last week with the Napa Gold which is really the Mann filter.
Old Jul 7, 2008 | 09:04 PM
Jay-Impala-man's Avatar
Good pics and lots of detail. I may have to get a new oil funnel. I don't put many miles in a year's time, So I will only change mine once a year. I am putting in Mobil 1 0w-30w in my Crossfire. Thanks, Jay-Impala-man
Old Jul 12, 2008 | 03:36 PM
downwardspiral's Avatar
This thread convinced me to do the oil change myself, the car runs so much smoother! My filter looks like yours, next time im going to order the mbz one, because it looks like a much nicer part.
Old Jul 12, 2008 | 03:41 PM
If anything I would think you would lose performance due to increase turbulance under the car. The easiest ways to improve aerodynamics of a car are to remove the mirrors, lower the car, and reduce airflow/turbulance under the car. for what its worth id put it back on.
Old Jul 12, 2008 | 07:09 PM
I recommend the fleece oil filters.
Lots of discussion here on the forum about how they hold up better than paper filters.
http://www.germanfilters.com/2005-me...r-p-45203.html
Buy a 4 pack even cheaper.
Also 8 quarts will bring your oil level to almost full on the dipstick.
The photo shown is a fine oil level.
Old Jul 13, 2008 | 12:15 AM
I paid the same price for the POS I put in my car, I think I might buy the 4 pack now and change the other one out. That one looks alot like the K&N, Im going to order one into the store I work at to check it out, I'll post pictures if anyone's interested.
Old Jul 13, 2008 | 11:10 AM
Display_Name's Avatar
Since it was made in August of 2006, I doubt it is the original filter.
FWIW - Your new filter is a paper filter, not a fleece filter. It actually will do a great job filtering your oil, but it isn't up to the task of lasting a full 7,000 miles for a standard FSS oil change interval. For that you'll need to get a fleece filter.
ALSO, as far as the funnel, I've got a tip that can save you some time and effort. After removing the old oil and oil filter, simply pour the oil down the filter opening. It is a nice big target, and Mobil 1 bottle balance well on it to allows the bottle to drip out for a few second while you open the next bottle.
Old Oct 2, 2008 | 09:08 AM
LVXF's Avatar
Like your idea of pouring the oil into the canister. That's good for 8 quarts, but topping it off requires the old-fashioned way. Has anyone found a screw-on extension that fits a Mobil 1 bottle? Why couldn't they manufacture a container with the same size cap as the other oil manufacturers? What a PITA!
Old Oct 2, 2008 | 03:36 PM
caddyman3's Avatar
ha ha ha that paper filter looks like junk....go with fleece
Old Oct 2, 2008 | 04:43 PM
This is on the shelf waiting for the next oil change...
Old Oct 6, 2008 | 08:55 AM
cassidyrj1's Avatar
I dont know if i just have to worst luck in the world or what. I used to have a 04 coupe until i got hit and totaled it. But before that happened i took off the belly pan thing and i good sized rock flew up and got jamed into a pully and split my belt. I now have a 05 srt and am not taking it off. I was thinking that it would be a good idea incase you go over a speed bump or a grade that you might bottom out at. Its a nice protection.
Old Oct 6, 2008 | 09:26 AM
MikeR's Avatar
That piece of plastic wont help much if you bottom out on something hard. But it will keep loose stuff from flying up into the engine bay. Good luck to us all.
MikeR
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
lazorouss
Sep 11, 2015 09:16 AM
