Oil catch tank
Old Oct 23, 2008 | 02:59 PM
Tazz's Avatar
Default Oil catch tank
Anyone installed an oil catch tank on their Xfire? Tips on installing one ??? Thanks,
Old Oct 23, 2008 | 03:15 PM
tighed1's Avatar
Default Re: Oil catch tank
Did a quick SEARCH and found this.
Is this what you want?
https://www.crossfireforum.org/forum...ight=oil+catch
Old Oct 23, 2008 | 03:21 PM
Tazz's Avatar
Mine is a Limited (not supercharged) and I think installation should be a little simpler ????
Old Oct 23, 2008 | 05:03 PM
KrzyFast's Avatar
I would think it should be a bit easier with a Limited.
Brandon's idea works really well.
I used the same oil seperator (Husky, I believe)- I did end up having to seal the bottom petcock valve with RTV to get it to really collect the oil. I drain it every other fill-up now - nearly full each time.
Cheers,
KrzyFast
Old Oct 23, 2008 | 06:54 PM
TVT_DESIGN
Guest
Posts: n/a
Brandon's idea will work the same for N/A as SRT.
I installed two air/water seperators in line of the two oil hoses coming out of the valve covers. Catches a decent amount of oil.
I'm actually about to have one welded up that will look all pretty and stuff. I'll post pics when its finished.
Old Oct 23, 2008 | 10:57 PM
petty's Avatar
You may use an empty plastic oil container (1litre) and just make a hole in the top near of the spout and inert a breather pipe. Seal it both inside and out with a generous bead of silicone sealant.try to refer ere www.g37forums.com/showthread.php?t=68
The PartsBin Blog.
Old Oct 23, 2008 | 11:36 PM
BrianBrave's Avatar
<--- Huge Horsepower
I used this unit from JEGS - came with everything needed. Mounted it on the firewall using an existing bolt and to keep the hoses to a minimum..
Old Oct 24, 2008 | 04:49 AM
TVT_DESIGN
Guest
Posts: n/a
I used the same thing, but from Home Depot in the air tools aisle. Total cost was like $10.00 for 2.
Old Oct 24, 2008 | 08:06 AM
delornut's Avatar
I'd guess blow by would be a problem more consistant with the STR6. Because of the supercharging crankcase pressure could go from negative to positive if there is any leakage around the rings. With 20,000 miles on my Limited I haven't seen any of these problems. Maybe I should knock on wood.
DeLornut
2006 Limied Coupe
81 DeLorean
Old Oct 24, 2008 | 07:03 PM
BrianBrave's Avatar
Yea - but those are ugly....
Old Oct 25, 2008 | 05:31 AM
waldig's Avatar
Development on this separator is going forward, I was welding up Mod2.0 yesterday which should do better. Stainless steel media separates the mist from the vacuum line, without VERY LITTLE RESTRICTION. This is to reduce the crankcase pressures and free up some additional horsepower; lost due to windage.
Learning to TIG Woody
Old Oct 28, 2008 | 03:11 PM
satellite's Avatar
Sweeet....Woody you are on top of everything, thanks for all that you do... I will keep checking back on this project for sure.
TerryR
Dec 13, 2019 03:27 PM
paine2907
Oct 2, 2015 10:01 AM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
