anybody ever have a temp sensor go bad?
Old Nov 16, 2008 | 11:51 AM
taylormanss's Avatar
Default anybody ever have a temp sensor go bad?
just checking what symtoms you might have had.
Old Nov 16, 2008 | 12:06 PM
Moparrbust's Avatar
Default Re: anybody ever have a temp sensor go bad?
I've replaced many bad temp sensors................most were smashed or broken though.
Old Nov 19, 2008 | 04:50 PM
thomatt12's Avatar
I had the same problem before and just like Moparrbust, I've also replaced many bad temp sensors, they just malfunction and gets broken...
_______________________
Chrysler Concorde Accessories
Old Nov 19, 2008 | 05:10 PM
Squirrel Crusher's Avatar
My ambient temperature sensor got bumped from the side. Replaced the lower grill and temperature sensor. The sensor's plastic mounting bracket now want securely hold the sensor after the side bump causing the hole to slightly enlarge. You might know the cheap plastic bolt on bracket isn't a replacement dealer part. If I can't find a wrecked crossfire somewhere to remove the part,I'll have to melt the bracket with a heat gun then squeeze the hole back smaller. Squirrel
Old Nov 19, 2008 | 06:05 PM
tighed1's Avatar
How about a dab of black silicone?
Old Nov 20, 2008 | 02:14 PM
ImportLabSRT's Avatar
Which temp sensor?? I have never replaced a coolant sensor on a Benz engine other then being broken by user error. IAT sensors do go bad after time and the ambiant temp sensor brackets get broke often.
rampntlion
21
Feb 11, 2019 08:18 AM
steps
Oct 13, 2015 06:18 PM
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
bobbie
Sep 12, 2015 12:49 PM
