Wiring for Angel Eyes
Old May 28, 2009 | 06:22 PM
ZeroZero's Avatar
Default Wiring for Angel Eyes
Hi All
I need to wire up my new Angel eyes (four light rings), But i can not find a way to run the wiring from the dash to the headlamps/engine bay . I was thinking of using the drivers side heated seat switch ( as that one is not working anymore) , So will this switch be suitable & where is the best place to run the wiring ???
Cheers
Andy
Old May 28, 2009 | 07:27 PM
TaReGt's Avatar
Default Re: Wiring for Angel Eyes
You have andgel eyes inside of your car? If they are, where i think they should be, in headlamps, wire them to daytime running lights.
Old May 28, 2009 | 07:57 PM
ZeroZero's Avatar
Hi Taregt
Yes the Angel Eyes are inside my headlamp units & i do want to use them as day time running lights , But i want to be able to switch them off when the main headlamp are switched on , so i was hoping to use this spare switch in the dash ,
Cheers
Andy
Old May 28, 2009 | 08:07 PM
TaReGt's Avatar
Hmmm... May i ask why would you do that?
And how did you manage to put them in?
Old May 28, 2009 | 08:35 PM
There is an easy way to do this without going into the cabin. Use a standard 5 pin relay (we refer to them as a bosch relay). Connect your angel eyes to a fused battery source, and run them through the "normal closed" contacts (30 and 87a) of the relay. Splice the coil circuit (85) to your headlight wiring, (86) to ground. I can draw a diagram if you don't understand.
That way when you turn on your headlights, the relay will engage, turning off your angel eyes. You are using the relay to turn off an item rather than turn on an item. You can get them in ranges from 20a to 50amp. Not sure what the angel eyes draw.
James
Old May 29, 2009 | 05:13 AM
ZeroZero's Avatar
HI James1549
Now that would be very cool , So if i only want to turn off the outer rings when the dipped headlamps come on i can only wire the outer rings this way & keep the inner ring turn on all the time .
Cheers for the help
Andy
Old May 29, 2009 | 09:57 AM
mdaniels4's Avatar
So, assuming that there may be at least one other member who'd like these DT running lights on theirs, where did you get them, and how did you get them inside the light module?
Old May 29, 2009 | 10:05 AM
Andy,
After looking over my directions I need to make one correction. You need to hook up the angel eyes to an "ignition" circuit under the hood. That shouldn't be a problem with the electric box mounted under the hood. If you don't use an "ignition" power source, they will remain on all the time. Sorry about that.
You can connect both sets to the same "ignition" circuit, just have one set bypass the relay to get the effect you are after. Be sure you have them properly fused for protection.
James
Old May 29, 2009 | 06:57 PM
ZeroZero's Avatar
Hi James1549
Arhhh yes i was thinking about not wanting a flat battery every time i got back to the car , I have very little understanding of the Xfire layout , So your saying i could wire into the ignition circuit via the fuse box under the hood , sorry about this could you post a picture please , I have aguy at work who can work on the wiring up so the more infor i give him the better.
Cheers
Andy
Old May 29, 2009 | 07:03 PM
ZeroZero's Avatar
Hi Mdaniel4 & Taregt
I have posted most of the build of my Angel Eyes in the UK section
https://www.crossfireforum.org/forum...d-fitting.html
I still have some more picture to post ,As i now have the Headlamps with Angel eyes in the Xfire , Just need todo the wiring thing .
Cheers
Andy
Old Jun 1, 2009 | 04:54 PM
ZeroZero's Avatar
Hi All
So hows this comments please
These picturs are taken in very bright sunshine
Jame1549 would i be able to have the outer rings on in the day & the inner ring on at night with the headlights . Yea if you could draw the circuit that would be a great help
Cheers
Andy (Angel-Eyes) UK
Old Jun 2, 2009 | 09:40 AM
///SilverSaphRT6's Avatar
Those are Hott!! Nice job!
Old Jun 10, 2009 | 09:03 PM
dealer6550's Avatar
night time pics please?!?!?!
Old Jun 11, 2009 | 12:22 AM
beasticles's Avatar
I wish this was an easier install! I think we would all have a set!
Old Jun 11, 2009 | 03:08 AM
nox1s's Avatar
those sure are... blue...!
why didn't you opt for a "white" light?
Old Jun 11, 2009 | 07:22 AM
ZeroZero's Avatar
Hi nox1
The rings by themselfs are a very pale blue , But with the respray of the back plate to body colour (RED) , i think its bringing out the blue/purple , They are alittle bit too dark for my liking , But hey this is my first set of Angel Eyes & i can always get the back plate resprayed a different colour , Anyway i had to get the blue as the shop was all out of white , I need to try a few different background colours & see which one gives me the result i was looking for .
Cheers
Andy
Old Jun 19, 2009 | 07:47 PM
ZeroZero's Avatar
Hi all
3 pictures showing the 'james1549' set up.
Outer rings on from engine start , All 4 rings on with the side lights , Inner rings stay on when the headlamps are switched on .
Cheers All
Andy
Sep 28, 2015 07:40 PM
JEFASOLD
Sep 28, 2015 12:10 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
bobbie
Sep 12, 2015 12:49 PM
RiderJC
Sep 7, 2015 11:19 PM
