Blue fluid leak from behind RF wheel
Old Jul 15, 2009 | 02:58 PM
LugNut's Avatar
Question Blue fluid leak from behind RF wheel
I'm giving my "new" 2005 coupe the once-over after having it sit for a few days (waiting not so patiently ).
There was a dollar-coin size puddle of blue fluid on the floor just behind the right (passenger's) front tire. There were traces on the very bottom of the fender, but no signs from above (around the battery, etc.).
The fluid didn't seem acidic, so I don't think it was the battery. Unfortunately both the antifreeze and the windshield washer (WW) fluids are both blue, and of similar "feel".
I'm guessing the WW reservoir or line (pump under there too?). What say you?
If I pull the front tire and remove the black plastic inner-fender splashshield, are the WW parts accessible? I don't have a service manual yet.
Thanks!
Old Jul 15, 2009 | 03:05 PM
maxcichon's Avatar
Default Re: Blue fluid leak from behind RF wheel
Where is the washer bottle? Right place? Driver or passenger?
Old Jul 15, 2009 | 03:44 PM
LugNut's Avatar
It's behind that fender (RH side). I see some pics on the site.
Others: no, I haven't added any WW fluid yet, so it's probably not just overflowing.
Old Jul 15, 2009 | 04:17 PM
mdaniels4's Avatar
it'd be the ww fluid in that spot, more than likely a hose split, or coupling washer dried. Pull the wheel skirt, it's all right there. Mine froze this winter, and pulled the skirt, put a heater there, drained it and refilled to a colder allowable and that was that. Might be a crack in the bottle, but I really doubt that
Old Jul 15, 2009 | 04:23 PM
robby363's Avatar
Yuo can find a service manual here if it's any help. https://www.crossfireforum.org/forum...ollection.html
Old Jul 15, 2009 | 04:41 PM
apkano's Avatar
Life is random...so am I.
It's just windshield washer fluid.....that's exactly where the overflow is.
I've had mine leak out on hot days, parked on a slight incline, etc. I wouldn't worry too much about it.
Old Jul 15, 2009 | 04:53 PM
downwardspiral's Avatar
+1. . I would also check the hose to make sure it's not backing off the nipple on either end. My last car's washer hose would fall off the nipple on the sprayer. When I sprayed it, there would be a little puddle under the car, even if the fluid made it to the windshield.
Old Jul 15, 2009 | 07:32 PM
LugNut's Avatar
Looks like I get to take apart that wheelwell ...
Thanks all.
Old Jul 15, 2009 | 08:30 PM
I wouldn't mess with it yet. If it had a leak, it would be more than you described. Give it some time.
James
Old Jul 16, 2009 | 10:58 PM
LugNut's Avatar
Hmmm ... no leaks today. And tried the washers for the first time, and there's fluid. So maybe the seller had it overfilled? Odd that there's no dipstick -- would be an easy improvement.
Old Jul 17, 2009 | 11:18 AM
ppro's Avatar
It's Vulcan blood! You must have the Startrek Version of the Crossfire!
Seriously it's just windshield washer fluid leaking from the overflow. Strangely, in the day of containing every fluid in the car and preventing it from just leaking onto the ground, Mercedes, er I mean, Karmann, er I mean Chrysler designed the washer tank to overflow directly to the ground.
There's a sticker warning that overfilling may cause spillage.
There's another thread on here all about it.
https://www.crossfireforum.org/forum...luid-tank.html
You do not need to take it apart (unless you want to put an overflow tank on it and tell us about it )
When the low washer fluid warning comes on, you should be able to put a gallon in without overflowing and have enough margin to keep it from overflowing due to expansion.
Old Jul 17, 2009 | 05:56 PM
Sandgrounder's Avatar
Was in Vulcan, Alberta on the 1st of july, and no leak's of blue fluid , pink fluid the day before when I filled the washer tank with anti bug fluid . Any dip stick would be an improvement especialy on the transmition system,
Old Jul 18, 2009 | 01:23 PM
The big question is why have an overflow, why not plug the overflow and fill the tank to the brim? Makes sense to me to see that it is full and not need to hear it splashing on the floor.
Old Jul 18, 2009 | 02:31 PM
hey, you just might be on to something here. Let pressurize the washer tank, and blast those bugs away...
Old Jul 28, 2009 | 03:27 PM
the.Santorini's Avatar
Talking Re: Blue fluid leak from behind RF wheel
Originally Posted by LugNut
The fluid didn't seem acidic....
How did you determine this...I hope by not taste-testing... LOL JK
Old Jul 28, 2009 | 05:54 PM
LugNut's Avatar
Anitfreeze is slightly slippery. Battery acid burns, eats at the concrete floor, ... and ruins brand new pairs of Levis.
Washer fluid often has a slight ammonia odor.
Haven't noticed any more leaks, but haven't been looking either. But I'd guess it was just too full.
Old Sep 9, 2009 | 07:15 AM
LugNut's Avatar
Well ... apparently was not too full. My washer warning light has activated, and I've never used the wiper fluid. But haven't seen more leaks.
"You do not need to take it apart"
Appears that I will need to, maybe this weekend. Hoping it's just a leaking tube, and not a cracked tank.
Old Sep 16, 2009 | 05:06 PM
LugNut's Avatar
Question Re: Blue fluid leak from behind RF wheel
Took it apart. Bad news -- tank is leaking. The lower support/bolt, on the bottom, rests right on a molding/jointing seam in the tank. Vibration seems to have gotten the best of it. New "washer reservoir" on order -- hopefully they have one in stock.
After pulling the wheel, I couldn't get the inner splash shield all the way off. Removed the two metal screws from underneath the car and pried the lip of the PVC rocker (using a putty knife) from over the shield, but the black plastic shield still wouldn't come out. Seems like the shield was hanging-up on the nuts for the two underneath bolts. Anyone else experience/tackle this problem?
Old Sep 16, 2009 | 10:15 PM
I think its burried behind the fender, when I had a replacement RF fender(due to my X -Boss inability to reverse), it was exposed with the fender removal
Old Sep 16, 2009 | 10:56 PM
[quote=LugNut]Took it apart. Bad news -- tank is leaking. The lower support/bolt, on the bottom, rests right on a molding/jointing seam in the tank. Vibration seems to have gotten the best of it. New "washer reservoir" on order -- hopefully they have one in stock...........quote]
The price these puppies are I think that I would try and repair it. You have to find something that sticks to PE?
Fiber glass seems to work.
