Oil change parts needed
Old Sep 11, 2009 | 09:44 AM
daniboy17's Avatar
Default Oil change parts needed
ALL,
I am a newcomer on the forums here, and also a recent owner of a 05 Crossfire Limited coupe, i have been doing some reading but i am still unclear on what i need to change the oil on my crossfire. any help would be appreciated, im a newbie to cars so im not sure if i should just buy the parts i need and take it to a benz/chrysler dealer and have them change it??
Old Sep 11, 2009 | 09:56 AM
maxcichon's Avatar
Default Re: Oil change parts needed
Originally Posted by daniboy17
ALL,
Welcome!
8.5 quarts of Mobil1 0W40 (Euro) oil and a fleece filter/kit. The filter is not your usual can type, it is installed on a spit arrangement from the top.
Use the search function and you will find plenty of threads on this subject.
Pleanty of them.
Most folks use a suction-type device to extract the oil through the dipstick tube. This is the way Mercedes will do it. Others do the normal jack it up and drain it. There is a replaceable washer/gasket if you go that route.
Do some reading and it will be clear!
www.slkworld.com has a great how-to section. Our cars are built on the R170 platform and these how-to's work for us.
Mostly.
Old Sep 11, 2009 | 04:47 PM
32krazy!'s Avatar
8.5 qts is only for the supercharged 3.2 litre engine. if your are n/a engine your looking at approx 6 qts.
new crush washer needed if drained from the bottom. fleece filter and o rings
Old Sep 11, 2009 | 05:09 PM
Drivers Handbook and shop manual says that, everyone else says different.
I'll go with what the general consensus is, 8 liters give or take.
Old Sep 11, 2009 | 05:14 PM
corfire's Avatar
My N/A (2004 Coupe) takes 8.5 qts of oil? However, I just use 8. I think that the 04 owners manual incorrectly lists it as 6 qts.
Old Sep 11, 2009 | 05:18 PM
ALL require 8.5 quarts.
This is out of the 2004 Owners Manual:
Old Sep 11, 2009 | 05:53 PM
Man I hope you take it in for your oil changes, if not, I hope you have plenty of $ for all those engines every 7000 miles or so... Going volume for this engine (NA M112) is 8.5 qts sometimes minus a half of a qt. when you change it.
Old Sep 11, 2009 | 06:09 PM
ALL,
Oh, welcome to the forum. I just added you to the list of Texas Crossfire owners: https://www.crossfireforum.org/forum...mber-list.html
Also, are you aware of the BIG get together later this month?: https://www.crossfireforum.org/forum...sept-26th.html
Old Sep 11, 2009 | 09:13 PM
8.5 in my '04. Don't trust everything you read. Filter 7078 at NAPA. James
Old Jul 25, 2017 | 08:52 PM
Billto's Avatar
Changed my oil and filter in June of this year, YUP, it took 8.5 quarts. I used the MityVac oil extractor and filled it up to with-in two inches from the top. N/A 2004 coupe.
Bill T.
Old Jul 25, 2017 | 11:53 PM
Bill T.
This thread is 8 years old and is in error.. You are of course correct.
Look at the thread date before answering it.
Old Jul 26, 2017 | 02:18 AM
T. K. D.'s Avatar
Default Ansa muffler advise
I'm looking to put the Ana's sport muffler on that I purchased nearly two years ago. I have somewhat of a delima.
1. Had to purchase my own stainless steel pipe, flange and hangers, because every muffler shop seems to only use aluminized steel; now I'm told the can bend it but not a mandrel bend, so bends won't be uniformed.
2. I dont care for the Ansa straight round tips, but don't want to cut off original tips ( so I can always go back to original). I have to sets of other after market stainless tips, but so far no shop can bend. 2" dia. Pipe in a 5" approx. length in a "s" shape/curve like the original muffler exists.
For the work around this particular road block, I've considered using stainless flex piping to connect my tip options. What do you guys think of flex exhaust pipe used to connect tips to muffler or flex pipe in general?
Old Jul 26, 2017 | 06:59 AM
Default Re: Ansa muffler advise
In an outdated oil change thread?
Old Jul 26, 2017 | 11:32 AM
Billto's Avatar
ALL,
Once you move around the Forum you will notice most if not all folks say stay away from dealerships. People here on the Forum will steer you straight. search: "Oil Changes" I bought a MityVac Oil Extractor which works GREAT. and no mess. Check it out.
Bill T.
Old Jul 26, 2017 | 11:36 AM
Billto's Avatar
N/A 6 quarts >>>>> WRONG!
Old Jul 26, 2017 | 11:44 AM
After 8 years he has probably figured that out
jonq67
Jul 5, 2015 04:00 AM
Ephr8a
Jun 4, 2015 12:42 PM
chuckhaze
Mar 31, 2004 03:36 PM
Galen Dracos
Dec 28, 2003 01:07 AM
X-fired
Jul 29, 2003 01:38 PM
