Key Fob Does Not Work
Old Sep 11, 2009 | 02:46 PM
julieg's Avatar
Default Key Fob Does Not Work
Hi, I am new to this forum. I have a 2005 Crossfire with 2 keys that came with the car when I purchased it new in 2005. The key fob I always use works fine, my extra key fob is not working (car will not unlock and I am standing next to car trying). The last time I used it was about 6 mos. ago. I have read many posts here but still have some questions. Is there a battery in the fob? If so hw do you get to it and where can I buy the battery? I will try to program the fob again the way it is talked about on another post (put key in ignition, hit unlock twice, car should start) but can't do it now, I am at work. I just spoke with my Chrysler service advisor and he does not know if there is a battery in the fob and also said I would need to get a new fob from the factory. Also, I have seen posts that state the fob won't work but they open the door with the key - how do you do that? Your comments and suggestions would be appreciated. I really don't want to have to buy another fob - I think they are about $150
Old Sep 11, 2009 | 03:07 PM
nox1s's Avatar
Default Re: Key Fob Does Not Work
There are two batteries. Look at the back of the fob, you should be able to pry off the back cover on the bottom. Make sure the key is out, it'll make it a lot easier.
Batteries MIGHT be dead, not sure. I think they're about 7$ for two..
Try putting the fob in the door handle to see if it'll unlock, and in the ignition to see if it starts. There's a tiny RF transmitter in the key fob and if it's not the right one for your car (possibly someone gave you an extra wrong key by mistake?) it'll NEVER start.
Old Sep 11, 2009 | 03:09 PM
tighed1's Avatar
Hey Jewels here's a great post by Tom on opening the fob.
https://www.crossfireforum.org/forum...estroying.html
Welcome to our world!
Old Sep 11, 2009 | 03:12 PM
Stogey's Avatar
Quick easy way to check the batteries is to watch the red LED on the front and press a button. The LED should flash once. If not, I would say replace the batteries.
Welcome to the Forum, your home for Perma-Grin Support !
Old Sep 11, 2009 | 03:17 PM
julieg's Avatar
nox1s, thanks for the reply. The fob did come with the car and was working a few months ago. I will check the batteries when I get home from work.
Old Sep 11, 2009 | 03:19 PM
robby363's Avatar
The batteries are easy to replace. You will need 2 CR 2025.
Old Sep 11, 2009 | 03:20 PM
julieg's Avatar
Thanks everyone. I will check this all out and let ya'll know what happens.
Old Sep 11, 2009 | 03:23 PM
julieg's Avatar
thanks robby363
Old Sep 21, 2009 | 10:05 AM
julieg's Avatar
Hi everyone. Finally got the new batteries over the weekend & my spare key fob is working again! Thanks for everyones posts.
Old Oct 15, 2009 | 06:17 PM
Uncle_Al's Avatar
Bought a 5 pack from batterybob.com. Cost $7 including shipping and handling. His batteries may be fresher than your local Radio Shack. I'm sure he moves a bunch of these.
Old Apr 17, 2015 | 08:26 PM
massgold's Avatar
Hi everyone just picked up our crossfire convertable Wednesday and one key fob not opening doors or locking. I put new batteries in and I can see the light flashing on the red led panel but still not working. Any suggestions
Patrick the new guy from Port Colborne
Old Apr 17, 2015 | 09:48 PM
Mrmiata's Avatar
Welcome new guy from Port Colborne!
Press the lock or unlock button twice on the fob in question.. within 30 seconds insert the key and turn it to the on/run position. This should "reset" the fob to the car.
Old Apr 18, 2015 | 10:24 PM
massgold's Avatar
It worked . Thank you very much
Old Jul 18, 2016 | 09:12 PM
spa59's Avatar
Smile Re: Key Fob Does Not Work
Thanks Mrmiata it worked. I was unable to lock/unlock car but still able to start it. Changed batteries but still no joy. Reprogramed the key as you suggested and it worked.
Some suggestions -when you press the unlock/lock on the fob if the red light on the front of the key does not flash its new batteries-if it does flash try "reset" function as above.-its easy and it worked for me.
waldig
Jul 31, 2017 09:46 AM
spoiler
Sep 2, 2015 08:56 PM
UrbanE
Jul 16, 2015 01:39 AM
66L72M21
Jul 15, 2015 04:23 PM
Fildo Dog
Jul 6, 2015 05:20 PM
