Check Engine light and Vibration from engine.
Old Nov 5, 2009 | 01:47 PM
Mr.Troy's Avatar
Default Check Engine light and Vibration from engine.
Hi, I've been searching in this forum for a thread that has something about the engine vibrating at stops and the Engine Check light turning on and off on it's own. I'm from Mexico and took the car to the dealer and told me that the code was a cilinder missfired but was not an active one, so they just ereased the code and that was it (no charge for it) but the car is still vibrating at idle sometimes. Does anyone has a clue about this? Thanks!
Old Nov 5, 2009 | 03:49 PM
Bladecutter's Avatar
Default Re: Check Engine light and Vibration from engine.
Your best bet would be to look at the simple stuff on your own, first.
If it was me, I would start by making sure the air filters were clean, and then next up would be to pull the spark plugs out one at a time and make sure each one of them was at the proper gap.
After that, I would use a timing light to see if I could figure out which cylinder it is that is misfiring. Once I found the misfiring cylinder, I would switch the ignition coil over to the adjacent cylinder to see if the missfire them follows the ignition coil, or if it stays with the cylinder.
If that doesn't change anything, I would switch the fuel injector over to the adjacent cylinder to see if the missfire them follows the fuel injector, or if it stays with the cylinder.
The results of the last test would then lead to further research.
BC.
Old Nov 5, 2009 | 04:07 PM
Mr.Troy's Avatar
Hi and thanks for the info, and for correcting my spelling since that I found a lot of info in the forum about my problem, and definitly will do what you told me, thanks again!!
Old May 20, 2010 | 05:42 AM
firemen's Avatar
BC.
Thanks dude for your help. I was trying to figure out my car sounds like there's also an electrical fault somewhere. the only time that light comes on is if i can't get the car into third quickly enough.
jgreen
106
Sep 18, 2017 11:46 PM
spoiler
Sep 2, 2015 08:56 PM
axnguyen
Jul 21, 2015 11:41 AM
Mark McKay
Jul 17, 2015 01:18 PM
TOPLA
Jul 14, 2015 07:46 AM
