Sensor in grill
Old Dec 2, 2009 | 04:16 PM
Larry Shively's Avatar
Default Sensor in grill
Anybody know what this sensor is? I was taking out the left hand lower grill and found a pointed sensor extending out of the grill. Impact/air bag sensor?
Old Dec 2, 2009 | 04:19 PM
2005 Ragtop's Avatar
Default Re: Sensor in grill
Larry,
What you're seeing is the temperature gauge OAT temp probe.
Old Dec 2, 2009 | 05:55 PM
beat me to it....lol
Old Dec 2, 2009 | 08:32 PM
MikeR's Avatar
If you disconnect it and turn the car on, your temp reading will be -36 degrees.
(hey, I was bored and I had to look at something while bleeding the brakes! )
Old Dec 5, 2009 | 12:50 PM
snowtop57's Avatar
My temps been reading -36 degrees for a while. Is this probe a dealer only item?
Old Dec 6, 2009 | 01:04 AM
MikeR's Avatar
snowtop, it took me a while but here is the replacement sensor....you sure yours isnt unplugged??
Ambient Air Temperature Sensor - Ambient Temperature Sensor, Ambient Outside Air Temperature Sensors
Old Dec 6, 2009 | 01:08 AM
tighed1's Avatar
LOL!
Thanks for the laugh Mike!
Old Mar 24, 2010 | 07:08 PM
Darticus's Avatar
I took out the grill but there was no wire hooked to the sensor is something wrong? The temp is still reading. Thanks Ron
Old Mar 24, 2010 | 10:24 PM
Let me guess, the temperature says -32.
Old Mar 25, 2010 | 09:12 AM
ZAHANMA's Avatar
Probably. Make sure you are looking at the correct sensor. This sensor is located in the lower louvre on the driver's side. Through a bit of research I believe it actually has two different types of signals being sent from the sensor. One is directed towards the dash to show you the ambient temp and the other signal is sent to the ECU to inform the ECU of changing ambient temps. If the dash sensor reads -36* there is a good chance your ECu is receiving the same. If it is NOT -36* outside this will cause poor gas mileage as the ECU is cumping more fuel to the engine to help maintain proper engine temps (in a -36* environment). Replacing the ambient sensor is a cheap fix, $30 shipped from chryslerparts.net. If your wires are visibly disconnected I would seek out a Chrysler mechanic to diagnose and propose a fix for the issue.
Old Mar 25, 2010 | 02:04 PM
Darticus's Avatar
Thanks guys, everything is good now and problem solved. Ron
Old Mar 25, 2010 | 03:06 PM
ZAHANMA's Avatar
What did you do to remedy your problem?
Old Mar 25, 2010 | 05:21 PM
Darticus's Avatar
I really didn't have a problem. I thought that probe was connected to the grill and thought it came off with the grill and no wires connected. Didn't realize the prob stayed connected to the car, I'm a dummy! Sorry for driving everyone nuts. Ron
Old Mar 26, 2010 | 12:25 AM
snowtop57's Avatar
Is it possible that some Crossfires have different mounting areas for this sensor?
2 years ago I removed both of my lower grilles to install the mesh insert overlays, when I removed those lower grilles, my temp probe was not attached to either of the lower grilles, nor did I see it dangling anywhere. Since that time, my drivers side lower grille fell off somewhere along the road, this in turn caused some damage to my inner fender and all the other plastic pieces behind the bumper and then I noticed the probe dangling by it's wire, now the temp inside the car reads -36. I am in the process of having my SRT bumper cover painted, but I'm also trying to figure out all the other pieces I need to replace. I already have a new temp probe so I will eventually figure out where it's supposed to be mounted.
55chevy
Jul 22, 2024 02:31 PM
TerryR
Dec 13, 2019 03:27 PM
rampntlion
21
Feb 11, 2019 08:18 AM
caseydeankopp
Sep 13, 2015 07:25 PM
bobbie
Sep 12, 2015 12:49 PM
