Check oil light on after changing oil and filter
Old Mar 30, 2010 | 02:36 PM
pandableuw's Avatar
Default Check oil light on after changing oil and filter
Hi everyone,
I changed the oil myself over the weekend, and the check oil light is still on. (it was on before oil change). I checked the oil level on the dipstick and it's just below max. I did replace the plastic rings on the filter assembly... is there something I missed?
What's going on?.. do I need to reset the light?
Old Mar 30, 2010 | 02:56 PM
Rob M's Avatar
Default Re: Check oil light on after changing oil and filter
check out this thread:
https://www.crossfireforum.org/forum...ing-issue.html
Old Mar 30, 2010 | 10:12 PM
magneticred's Avatar
If by oil light you mean the flexible service schedule wrenches for oil changes, follow the instructions from page 114 of the owners manual:
1. Turn key to the ON/RUN position.
2. Within one second press the ****/button twice.
3. The present status for days or distance is displayed.
Within 10 seconds turn the key to OFF/
LOCK.
4. Press and hold the ****/button, while turning
the key to ON/RUN again. The present status for
days or distance is displayed once more. Continue
to hold the ****/button.
After approximately 10 seconds, a signal sounds and
the display shows 7,000 miles (Canada: 11,000 km) for
approximately 10 seconds.
5. Release the ****/button
You may have to try this more than once.
If by oil light you mean the light that looks like an old oil dispencer / oil lamp, then you have a low oil level. It can be checked not only with the dip stick, but from the display:
A sensor in the oil pan allows oil level to be checked
without opening the hood. It provides an accurate measurement
of oil level, whereas the low engine oil level
indicator warns that oil level is definitely too low. With
the vehicle parked on a level surface, the engine is
warmed up and shut off for approximately five minutes.
When the ignition switch is turned to the ON/RUN
position, an ISO oil level icon appears in the trip odometer
window and a “clock” icon in the cumulative
odometer display. Pressing the **** to the left of the
speedometer twice within one second displays one of the
following messages:
OK
-1.0 Q (-1.0L)
-1.5 Q (-1.5L)
-2.0 Q (-2.0L)
HI
Remember your car uses 8.5 quarts.
Old Mar 30, 2010 | 10:35 PM
XF1RE's Avatar
LOCK.
following messages:
OK
-1.0 Q (-1.0L)
-1.5 Q (-1.5L)
-2.0 Q (-2.0L)
HI
Is this also on the "base" models? Every time I try this with my base coupe(after it has been warmed up), I get a picture of an oil can and just a line like this: _
Old Mar 31, 2010 | 12:23 PM
But I put in only 8 quarts the last time, and now I don't get a "HI" alarm every time I take a curve too fast.
Not saying to only put in 8 quarts, but that's what I tried and it worked for me. NEver seen a low oil alarm light.
Old Mar 31, 2010 | 12:39 PM
rcompart's Avatar
Are you parked on level ground when you change your oil? Also, are you pulling the oil filter out prior to putting the drain plug back in? First oil change I did I wasn't perfectly level and I was in a hurry so I didn't let it all drain out. it's amazing that half a quart of oil will come out eventually if you let it sit for 15 minutes.
Old Mar 31, 2010 | 12:58 PM
yes to both of your questions, but see, I have only done one change.
The light coming on was before I did my change - the dealership changed it before I brought it home.
And I did check, it was right at "full" - I think it was Danimal at the Dragon who told me that it "was just oil sloshing around".
I saw the alarm a lot the weekend of the dragon. Never seen it since.
Old Mar 31, 2010 | 02:31 PM
Rob M's Avatar
You are 100% correct. Refilling the oil takes 8 quarts and no more. The capacity is listed at 8.5, but you never get all the oil out. Even after you warm your engine and then drain the oil for quite a while there is still a decent amount of oil that clings to the many surfaces inside your engine. If you replace 8 quarts of oil, the oil level will be close to the high level in the range on the dipstick even after you run the engine for a while and recheck. The computer check for oil level (see owner's manual) will also show oil level as "OK" with 8 quarts. 8.5 quarts will result in too high a level when changing the oil. the 8.5 quarts was valid for the engine's original oil fill only.
Old Mar 31, 2010 | 04:30 PM
dwilsonjr74's Avatar
wow that's nice...
Old Mar 31, 2010 | 04:59 PM
pandableuw's Avatar
thanks everyone. problem is when I check the dipstick level it's close to the max and way over the min. I don't want to put too much and have to take oil out... help!? is the light is the ISO can and drip.
Old Mar 31, 2010 | 05:11 PM
texas t's Avatar
Talking Re: Check oil light on after changing oil and filter
If u get a topsider fluid removal pump ,remove 1/2 qt , they are about 25$ at bass pro located in boat area.
Old Mar 31, 2010 | 10:25 PM
I agree 100% with adding only 8 quarts when you change the oil and checking the level before adding any more. Just because the car uses 8.5 quarts doesn't mean that you drain every last drop during an oil change.
Old May 10, 2010 | 08:13 AM
Ed Mahoney's Avatar
Just changed my oil 2 weeks ago ! Only added 8 qts & showed full right to the top !!! Im always careful n what the manual tells yuh !! You can always add to it, much harder to take it back out !!!!
Old May 10, 2010 | 09:53 AM
Jeep2Xfire's Avatar
Someone listed the FSS reset and that doesn't work on my car. Being a Volvo mechanic all we have to do is hold in the trip reset button with the key off/out, then turn the key to position II (run not start) and keep holding in the trip reset. This changes the FSS on my car instead of that complicated crap.
Just an option.
Also about the emptying of oil, because I'm a mechanic I have a lift I can do my oil changes at so I know most of you don't have this option but if you do you can always adjust the legs so that the car isn't level to aid in emptying the oil out. Granted the windage tray and other internals to the oil sump (pan) will preclude from getting rid of all the used oil, but there shouldn't be a 1/2 quart left in there I don't think.
Old May 10, 2010 | 10:42 AM
Originally Posted by pandableuw
Hi everyone,
I assume you mean the red oil can, maybe the sensor is broken or disconnected.
Old Apr 21, 2013 | 08:58 PM
Red Racer's Avatar
Red engine oil light keeps coming on. I had my oil changed, the receipt says 9 quarts then drove 1800 miles no problem. Then the engine oil light came on, slow down the light goes off, speed up it goes back on. Checked the oil and it looked ok. Dash says oil is ok. Drove 1500 miles and now the oil is brown? Help!
4drturbo
Jan 3, 2019 02:46 PM
Hoppy
Dec 7, 2018 07:36 AM
jgreen
106
Sep 18, 2017 11:46 PM
axnguyen
Jul 21, 2015 11:41 AM
skeet370
Jul 18, 2015 01:02 PM
