Crossfire Keys
Old Apr 25, 2010 | 05:31 PM
mifirefly's Avatar
Default Crossfire Keys
What is the easiest and fastest method to get a Crossfire replacement key, programmed and cut?
Old Apr 25, 2010 | 05:52 PM
robby363's Avatar
Default Re: Crossfire Keys
The dealer or maybe this place. https://www.remotesandkeys.com/Produ...ductCode=3191A
Old Apr 25, 2010 | 06:43 PM
IBLUBYU's Avatar
I just got a new key fob from my dealer last week.. $146.00 ...... took 3 days. Dealer said it didn't have to go to Germany. Came out of Texas. Had to have your Vin #. Still needed to do the simple programing instructed on this forum for free, to open and lock doors and panic button. Dealer said their charge to do that program was $45. Save the $$$ do it yourself! Ebay keys don't work.
Old Apr 26, 2010 | 11:56 AM
nox1s's Avatar
Do you know if once a keys been programmed to open/lock doors, it can be reprogrammed for another car?
I bought eBay keys for the casing, switched out the transponder/key, but not the motherboard. It starts the car fine, and unlocks it with the door handle, but I cannot for the life of me seem to program it for the buttons to work.
Old Apr 26, 2010 | 12:19 PM
Thirteendog's Avatar
Yes it should, do you have the instructions for programming it? I'll see if I can find them real quick.
Edit: Found it
Originally Posted by Shawnkey
This is straight from the Crossfire manuals supplied to the dealership, or if you are a Chrysler tech, I got it from Tech Connect.
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
  1. Insert the key into the ignition switch.
  2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Hope this is useful and saves you $100.
Shawn
Old Feb 23, 2011 | 09:41 AM
gtrguy's Avatar
I just bought a new key and fob from Remotes and Keys.com. It came just like the factory origional. Pre-programmed for my car. Total cost: $139.99 plus shipping. I t works perfectly right out of the box.
Old Feb 23, 2011 | 12:15 PM
bluecoupe's Avatar
Thanks for the tip!
Old Feb 23, 2011 | 12:28 PM
Each key is programedand cut for a specific VIN. I don't think any old key can be reprogrammed for a diferant vehicle eveen if you could change the actual cut key part.
Old Feb 23, 2011 | 01:12 PM
TerryR's Avatar
I have ordered one from the same supplier, just waiting for delivery now.
Old Feb 23, 2011 | 08:14 PM
dtinker's Avatar
Has anyone seen a key fob case. Mine is getting very worn looking. It works fine just looks grubby.
Old Feb 23, 2011 | 08:27 PM
bluecoupe's Avatar
Cheap enough replacement:
http://cgi.ebay.com/ebaymotors/Foldi...Q5fAccessories
Old Feb 23, 2011 | 08:44 PM
dtinker's Avatar
It is the same as the one the XF uses except for name, thanks.
Old Feb 24, 2011 | 05:49 AM
TerryR's Avatar
Dave,
Be very careful with replacement cases. Reading on this forum, if you search for it, replacement of the case is not as straightforward as you would think. It has been done, but from reading on this forum, a very delicate operation. On the forum somewhere, I remember reading a Good Post, with pictures and instructions. I will Contact you if I find it. I have just purchased a New Key from " Keys & Fobs", as I had a problem with mine, as well as it looking a bit chatty.
TerryR
Old May 6, 2011 | 12:31 PM
brus843's Avatar
Guys I need to replace entire key set , I heard that we can find it brand-new for no more than $60 is that true?I live in L.A. Does anyone know where can. I go to grab a new key ?
Thank you In advance
B.
Old Jul 31, 2012 | 02:02 PM
Dal's Avatar
Dal
Thumbs up Re: Crossfire Keys
Edit: Found it
Shawn
Awesome, thats just saved me a few quid
Old Jul 31, 2012 | 08:01 PM
Mrmiata's Avatar
Gentlemen - Start Your Engines !
For 60 bucks.. not bad for a spare backup..
Amazingkeys.com - Chrysler Key Cut and Code
well thats the cut and program fee.. cant seem to locate the key price.. but might be worth a phone call?
Old Jul 31, 2012 | 08:16 PM
Maybe I am not reading this right? The comments below copied/pasted here:
Includes up to 2 Chrysler product (Dodge, Jeep, Plymouth and Chrysler) keys cut and retrieval of your key code when available. Please add this item after you have made your key selection. This item does not include the cost of the keys nor does it include any transponder key programming that you may need.
So, what actually does this mean?
Old Jul 31, 2012 | 08:21 PM
Mrmiata's Avatar
Now I'm wondering.. as the main tittle states "cut and code"
Guess those in need could place a call and confirm... might just be fishing bait here too..
Keepmeinmind13
Jul 10, 2015 01:05 AM
mhajek18
Jun 17, 2015 01:35 PM
gtjl
Jun 10, 2015 02:44 PM
MJPowers
Jun 8, 2015 02:34 AM
gobraves423
Jun 6, 2015 07:03 PM
