Anyone have problem with Costco gas?
Old May 12, 2010 | 11:29 AM
wmphipps's Avatar
Default Anyone have problem with Costco gas?
Being kinda cheap by nature I was using Costco gas. Premium in Xfire and regular in 08 Nitro and 97 Wrangler. Within one week we experienced fuel sytem problems on all three cars. Xfire had both oxygen sensors fail and check engine light came on. Nitro also had a warning light come on and dealer said problem with number 5 injector and my Jeep started cranking a long time to start which is always a problem with fuel check valve. I fixed the Jeep by running a tank of shell premium along with a can of Seafoam in the tank which fixed it.
We have quit buying gas at Costco. I am just wondering if anyone else on the Forum has had similar problems with Costco gas.
Old May 12, 2010 | 04:47 PM
itsky's Avatar
Default Re: Anyone have problem with Costco gas?
I have had good luck here in Colorado with Costco. Unfortunately, they do put in ethanol here. Other than the reduced mileage, no problems. Perhaps you just got a bad batch of gas. It happens.
Old May 12, 2010 | 06:09 PM
msheredy's Avatar
No problems here.
Old May 12, 2010 | 08:26 PM
spotsbimmer's Avatar
No problems with their gasoline here, I run their premium in all 3 cars since they've been selling gas. Costco is like my 2nd home.
Old May 12, 2010 | 08:53 PM
Costco gas/cheap gas = low bid gas
After having a very bad and expensive experience with a low cost gas station many years ago, I'll never buy gas anywhere but a name brand gas station again. Roll the dice if you want, but not me.
Also, check your MPG with low cost gas vs. name brand. Most will see a better MPG with name brand.
Old May 12, 2010 | 09:03 PM
I don't use Costco, but it may be their tanks are bad, not so much the gas. This can happen with any gas provider. It happened to me a long time ago with Shell.
Old May 12, 2010 | 10:15 PM
I think the gas comes from the same refinery's, it just rolls out in no name tankers, same gas. I do not know of any no name refinery's, do you?
Old May 15, 2010 | 03:19 PM
Tazz's Avatar
Maintenance is a big part of the problem -- they ususally don't take care of the tanks, etc. and you get crap, water, etc.
And as a by-product of their volume, they sometimes run the tank down very low, so again you pick up the dirt etc.
We've had some cars with clogged or overheated cat's due to some of the impurities...........
Old May 15, 2010 | 04:40 PM
Erzer's Avatar
I use Phillips 66 for my cars/truck most of the time...never had an issue
Old May 15, 2010 | 08:43 PM
SRT SIX's Avatar
If I remember correctly, some of the auto mfg actually recommend only 3 brands, Mobi/Exxon, Shell and Chevron/Texaco. It has to do with additives, detergents and other secret ingredients. Could be just a bunch of hype, but I stick with those. Never had a fuel problem over the years.
I look it as the same thing with Mobil 1 synthetic oil. Most of us follow that recommendation as well.
Old May 15, 2010 | 09:15 PM
Do you have ethanol added to your gas in Toledo? Because the water-ethanol mix is at the bottom of the tank, the fuel pump may pick up a slug of this mixture, and the engine will run very poorly or perhaps die. Or, they could have exceeded the ethanol content posted on the pump. That is becoming a more common problem these days as it's used as an additive to reduce the price of the gas.
Old May 16, 2010 | 12:38 PM
If the pick up pipe is always at the bottom of the tank, then why wouldn't the pipe pick up dirt all the time. Surely the only way this would work is if the pick up pipe in the gas stations tank floated on the gas and took fuel from the surface.
I think the best explanation is that any sediment in the tank is stirred up when the tank is refilled by a tanker and the pick up pipe picks up the debris that is floating around.
The same philosophy would apply to debris in the cars tank.
I avoid buying gas at old gas stations which may have old and possibly leaky tanks. A gas tank that leaks and sits below the water table can let water in rather than gas out.
In years past abandoned gas stations were a major source of benzene pollution, hopefully they have been cleaned up but I doubt it.
Old May 16, 2010 | 04:05 PM
Infinite's Avatar
heres what you do.
talk to the manager at the costco where you filled up, explain what happened. he should ask for a sample of the gas. They will test it and see whats wrong. Then they normally pay your bills
Old May 16, 2010 | 04:17 PM
32krazy!'s Avatar
it was req. by law more than a few yrs ago that all gas stations remove the metal tanks and replace them with the commercial plastic tanks to combat leaks and contamination of the local watertables. this had to be done nationwide
Old May 16, 2010 | 04:32 PM
They were also double lined tanks with alarm sensors in the interstitial lining to detect leaks.
Old May 16, 2010 | 05:26 PM
bmorgan's Avatar
Cool..... a new word for me today. I love when I see a word on here that makes me go hmmmmm......
Old May 16, 2010 | 05:34 PM
32krazy!'s Avatar
so bob you go hmmmm a lot dont you!!
Old May 16, 2010 | 05:36 PM
No charge.
Old May 17, 2010 | 02:12 AM
DavidOv54367's Avatar
"Customers of a New York Costco think their vehicles were erroneously filled with E85 ethanol fuel mislabeled as 93 octane. Costco says it's bad gas, not E85, but is still paying to repair damaged cars"
Why You Shouldn't Buy Gas From Costco: Reason #3267 - E85 - Jalopnik
Bad Gas Mix-Up A Nightmare In Rockland - wcbstv.com
Old Jan 6, 2011 | 01:58 PM
maciek's Avatar
Smile Re: Anyone have problem with Costco gas?
I dont know if this is problem with gas from Costco. Lately i was filling my tank in all of my cars at Costco gas station and recently around december engine light came on in one of my cars. Normal driving and suddenly its like iam losing power. Car RPM goes up and down around 1000 RPM while on iddle. Dont have any clues what is going on. Suddenly in my other car malfunction light came on too. Is this Costco gas problem quality or whatever?
Thanks
