What is this Vacuum line for ?
Old Jun 20, 2010 | 10:16 PM
ModlessG's Avatar
Default What is this Vacuum line for ?
On the back of the engine above the transmission I have a Vac line that isn't attached to anything.It just hangs down touching the top of the transmission. Where should it be connected?
Old Jun 20, 2010 | 10:54 PM
Default Re: What is this Vaccum line for ?
Your photo needs to be larger to make it out. I checked my car for you. There is a rubber vacuum line dropping down from the throttle body area, then connecting to plastic tubing, that I assume goes thru the firewall into the dash area.
James
Old Jun 20, 2010 | 11:05 PM
Here are two pics in a dark garage with a drop-light.
Old Jun 21, 2010 | 08:35 AM
ModlessG's Avatar
OK this should be a larger picture. I am thinking that I bumped a hose when installing the Needs wings intake. Its hard to see anything behind the motor as it is real tight. The picture is from the passenger side looking down. Thanks for looking at this.
Old Jun 21, 2010 | 08:53 AM
tunaglove's Avatar
If you mean that larger black hose that aims at the trans. filler cap, I believe is a drain for the vent area. So no connection.
Old Jun 21, 2010 | 09:13 AM
ModlessG's Avatar
Yep that's it.Thanks! The car is going in for some repairs on Wednesday.I wanted everything buttoned up.The stock CAI is back on. The IC pump now has completely stopped working. As soon as it hits temperature its off. I am also going to have the multiple valve cover leaks fixed as well. I bought the car certified so might as well use the warranty. thanks again
Old Jun 21, 2010 | 12:27 PM
Thirteendog's Avatar
You went through a lot of work to bring a car back to stock, when the people working on the car don't know what a stock SRT looks like...
Old Jun 21, 2010 | 01:35 PM
Infinite's Avatar
Best post ever on this forum and i have it quotes to savor its epicness forever
Old Jun 21, 2010 | 06:52 PM
ModlessG's Avatar
The Needs wings is pretty easy to un-install. Probably took 15 minutes. I hope I get a mechanic at the dealer that at least knows what the car is.You haven't helped my confidence by the way.
Old Jun 21, 2010 | 07:02 PM
ask if they have a certified crossfire mech and you want to talk to him,, tell him the pump is bad,,if he is a a** he will say "we need to diagnosis the problem first,, " and you say this is my 5th srt6 and all of them the pump has failed,, once he knows you know something about the car he will not try any BS on you. jim
Old Jun 21, 2010 | 07:05 PM
32krazy!'s Avatar
you coukld fix the pump as well as the valve cover leaks and know it was done right if you did it yourself.
Old Mar 9, 2025 | 09:39 PM
Broken-arrow's Avatar
any idea what the small white line is by the trans cap?
mine was unplugged and was wondering what it could effect?
Old Mar 10, 2025 | 09:02 AM
NeedsWings's Avatar
Default Re: What is this Vacuum line for ?
connects intake manifold vacuum to climate control blend doors, needs to be connected or you will have a vacuum leak.
Old Mar 10, 2025 | 03:38 PM
red_2005_convertible's Avatar
The other end of the gray vacuum line goes through the firewall under/behind the battery. If you buy 4x6mm polyvinyl tubing, it makes splicing the lines together really easy it slides over the gray line, and makes a pretty good seal (you can use pvc pumping glue to really make it tight).
-Jerry
Ddave
Feb 11, 2024 03:10 PM
JeffS
Jul 11, 2019 11:01 AM
Blackly
29
May 30, 2018 04:53 AM
Snake Eyes
Sep 28, 2015 08:55 PM
Realiztik1
Aug 16, 2014 02:46 PM
