HI Oil Level Alarm
Old Oct 6, 2010 | 01:39 PM
Default HI Oil Level Alarm
During the Dragon Run this past Saturday, the HI Oil Level Alarm went off in my 07 Coupe. First time I've had this alarm. Changed the oil back in OCT/09 and added the 8.5 quarts of oil specified. Don't think I'm going to remove any oil at this point because I don't get the alarm anywhere else I drive the car. Didn't get the alarm going up Moonshiner 28 to Fontana. But did get it going down Moonshiner 28 going home (drove more aggressive since 'it was in my bones').
Anyone ever get this alarm at Fontana or anytime else?
Old Oct 6, 2010 | 02:21 PM
Default Re: HI Oil Level Alarm
When I FIRST got my car, I"d get the alarm on interstate on-ramps now and then, when making the curve at the end as I merged.
I have NO IDEA how much oil was in there, but I've done 2 or 3 changes since, always with 8 quarts of oil* - never seen the alarm again.
* Per Danimal's suggestion, he promised me I'd not see the alarm again.
Old Oct 6, 2010 | 03:02 PM
waldig's Avatar
Talking Re: HI Oil Level Alarm
Pull the dip stick and check level. I always run 1 extra qt, high on the dip stick because of turns. No issues here.
If level is high may be a sign of antifreeze or gas dilution of oil due to a stuck injector. Confirm meter reading but dont ever trust gauges.Woody
Old Oct 6, 2010 | 07:19 PM
I pulled the dipstick earlier today. Level is definitely high. All the way up to the upper end of the red material. Will investigate further tomorrow.
Thanks,
Old Oct 6, 2010 | 11:55 PM
manisusmc's Avatar
Thanks,
when I change my oil I always pour in 7 quarts and then turn the engine over a few times without cranking it to get the oil circulated, then let it settle and then check it, it's always about 1 quart to low for obvious reasons, however it's much easier to add a little oil than take out. The 8 quart instead of 8 1/2 should be the ticket because it should put the oil level dead center of the add-full marks on the dipstick. too much oil can be a problem
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
lazorouss
Sep 11, 2015 09:16 AM
