Roadster Antenna base gasket ???
Old Jan 8, 2011 | 09:56 AM
awilson40's Avatar
Default Roadster Antenna base gasket ???
Anyone know where I can get the gasket between the antenna base and the fender ?
I see no part number listing for just the gasket.
Thanks
Old Jan 23, 2011 | 07:10 PM
ALight's Avatar
Default Re: Roadster Antenna base gasket ???
I asked the body shop to replace that gasket and was told that the whole antenna was the only option. Hard to believe, so I am seeking an alternative to the OEM high $. Any guidance would be appreciated. Thanks.
Old Jan 23, 2011 | 07:19 PM
awilson40's Avatar
Mine just had a couple cracks so I used black RTV to seal it back together. Cant ever tell it cracked.
A new base runs $50 or so. Not bad but hard to believe you cant buy just the gasket.
Old Mar 10, 2017 | 03:46 PM
earlj's Avatar
I purchased an antenna gasket from X8R and it works great. You do not have to remove your antenna to replace the gasket. Another member used ths same gasket; however, he used silicone around the base before installing the gasket. You do not need the silicone to seal the gasket. The company that sells the product has a video on the replacement procedures and they do not use silicone or any other sealer. The important thing is to remove the old gasket and try to get as much gasket material from under the base as possible. Warm the seal before applying and you get a secure seal without using a gasket sealer.
Old Mar 10, 2017 | 04:14 PM
bluecoupe's Avatar
Is this the gasket you purchased?
https://x8r.co.uk/roof-bee-sting-aer...eplacement-fix
Old Mar 10, 2017 | 09:51 PM
Rpaczan's Avatar
I used the silicone because I wanted to prevent water potentially leaking into the trunk.
VW Golf MK5 V Golf Beetle Corrado Roof Aerial Base Rubber Gasket Seal | eBay
Old Mar 11, 2017 | 02:34 PM
Shamrock's Avatar
Purchase this from ebay. Use the gasket. I did and it works fine.
Car AM/FM Radio Roof Mast Antenna Base bracket for VW Passat Jetta Golf Cabrio | eBay
If you get to Wilmington, let's meet over coffee or a beer.
Old Mar 11, 2017 | 03:26 PM
Yep, me too. I ordered several and gave out to friends.
Old Mar 11, 2017 | 09:28 PM
earlj's Avatar
Thumbs up Re: Roadster Antenna base gasket ???
Yes! The gasket number is X8R-0064 I purchased the gasket on Ebay and it cost less money because I did not have to pay the shipping charge from England.
Old Mar 12, 2017 | 10:53 AM
performanceisland's Avatar
Great find, I had to make my own rtv silicone gasket on a crossfire before cause I coldl not find a replacement without buying the whole antenna.
Old May 22, 2017 | 06:11 AM
Kurtp13's Avatar
What about the rubber cover on the antenna. Is there a cheap substitute for that also?
Old May 22, 2017 | 07:18 AM
Yea, get this :
The antenna is a bit shorter than OEM, but it screws right on and to me looks even better.
Old May 22, 2017 | 12:01 PM
Kurtp13's Avatar
Looks like that is just the base. Not the whip. Do you have another eBay link so I don't get the wrong thing. Also if the antenna is shorter is my reception worse? I live in a fringe area and need all the help I can get.
EDIT I found a 16 inch mast and a separate gasket. Ordered 2 of each and total was less than $6. Hopefully these work but the investment was low.
Old May 22, 2017 | 01:07 PM
OK, I think this is the one I got :
Qook Car Roof Radio FM Antenna Aerial for BMW Z3 Z4 M3 Toyota VW Volkswagen Bora | eBay
Old May 22, 2017 | 04:46 PM
markr6754's Avatar
Talk about timing...I just noticed my antenna was cracked throughout the base this past Friday (before the deluge). I was able to purchase the last one from this eBay listing. It sure looks right...time will tell upon arrival. It won't get here before I leave on vacation, but I'll add it to the things to do on my return. Thanks for all that you do for this Forum, George.
Old May 22, 2017 | 04:54 PM
Mrmiata's Avatar
Here is another vendor of it..
Old May 22, 2017 | 04:59 PM
Kurtp13's Avatar
This is what I bought.
Gasket Price: US $0.88
Roof Antenna Base OEM Gasket Seal For VW Mk4 Golf Jetta Passat Bora EP | eBay
16 inch antenna Price:US $1.86 + 0.15 Shipping
16" Car Vehicle Screw-in Radio AM/FM Roof Antenna Aerial Mast Replacement P9R7 | eBay
These are the parts I was looking for. I don't need to get the base and throw it away.
Old May 23, 2017 | 05:28 PM
S8MS-01904's Avatar
Thanks for the links, just what I was looking for. Orders placed today 5/23/17.
Old May 23, 2017 | 06:12 PM
Kurtp13's Avatar
You're welcome. I forgot to mention that this antenna is also the production length which is what I preferred.
I also I like it when I get a link to follow so I am confident that I am looking at the same thing as the poster.
Old May 24, 2017 | 10:15 PM
One of the ladies in the East Coast FLorida Crossfires Facebook Page just changed her's today.
All by herself. Pretty cool when a BLONDE LADY can do it herself!
(You can meet Diana yourself this fall at the Dragon. )
