Check this out! Dynotest with iPhone
Old Apr 13, 2011 | 04:31 AM
FUBU's Avatar
Default Check this out! Dynotest with iPhone
Check this out! Innovate Motorsports OT-2 - Transform your iPhone or iPod into a wireless gauge, data logger, dyno, efficiency meter and OBDII scan tool.
Looks quite cool! ;D
Old Apr 13, 2011 | 05:23 AM
green-ghost's Avatar
Default Re: Check this out! Dynotest with iPhone
Anyone else remember rotorary phones attached to the wall
BTW FUBU, your item is in the mail, small white bubble envelope...dont poke your eye out
Old Apr 13, 2011 | 06:05 AM
FUBU's Avatar
Did not really get the first comment but is this just bogus? unneccessary to purchase?
Youre a star! Many thanks Pooly!
Old Apr 13, 2011 | 07:42 AM
ZAHANMA's Avatar
A couple comments. This is connected via the OBD-II port on your car. So yes it can technically measure any metric that the OBD-II reads. If you are in need of serious datalogging, this is not the way to go...here's why. The OBD-II port has serious issues with sampling multiple metrics at the same time on a high frequency rate (i.e. 1 sample/sec for multiple metrics). This will create a lag and make it difficult to properly datalog. Yes you could probably do one item at a time and measure that, but then if you do multiple runs with multiple metrics being record the environment and engine parameters will not be identical so they can not be compared against each other.
My $0.02
Old Apr 13, 2011 | 09:25 AM
FUBU's Avatar
My $0.02
So what you are saying: Don't buy it?
Old Apr 13, 2011 | 10:11 AM
ZAHANMA's Avatar
I'm not saying you shouldn't buy it...if you just want to casually review one or two things, or use it to clear any codes you may get. However, I wouldn't buy it if I were going to try and seriously datalog multiple engine metrics. I would recommend something specifically designed for datalogging, like the Zeitronics zt-2.
Old Apr 13, 2011 | 10:23 AM
FUBU's Avatar
Ok. Well I am after a machine that will be able to change my Fahrenheit to Celsius.. Miles to km.. :d
Old Apr 13, 2011 | 12:20 PM
ZAHANMA's Avatar
Oh yeah, I definitely don't think that will be able to do that. I think probably the StarDAS system would be the best way to get that done. Though you can't go out and buy one without some very deep pockets. Maybe someone close to you has one...and knows what they are doing with it.
...hell, you might even want to try the MB dealer near you, they might be able to help.
Old Apr 13, 2011 | 02:52 PM
MikeR's Avatar
IF you were to get the zt2 and DashDaq you could datalog, read & clear codes and display your engine parameters in metric. It would be a great addition for your car with your planned mods. Just getting the DashDaq will plug into the OBDII port and read & clear codes, data log the ODBII outputs and let you display the parameters of your choice. Without the zt2 you will still have the data speed limitations that Zahanma mentioned...
syfi
Mar 28, 2026 04:14 PM
eikon
Sep 9, 2019 10:16 PM
janaiy
53
Nov 2, 2015 09:23 PM
Charlesl
Sep 30, 2015 10:46 PM
grip grip
Other Cars Etc
Sep 26, 2015 09:52 PM
