New mods something Isnt right need help
Old Apr 23, 2011 | 10:09 AM
94Bravada's Avatar
Default New mods something Isnt right need help
In the last two weeks I added three new mods to my car all pretty Stright forward things but my car is acting up any input would be great. First I did a tune from eurocharge everything seemed great the car reved a lot quicker and didn't feel as bogged down when I got on it and the clutch felt a lot better, then about a week later I added a 74mm throttle body which seemed to bolt on and plug in with no problems and a NW intake at the same time. On start up the car reved but wouldn't come back down so I shut it off and restarted it and it seemed fine but my tune didn't seem to be there anymore, it seemed bogged down and the clutch felt the same again. The next day I drove it to work and at an idle it would rev about 500rpm so I pulled the batt to reset everything and then my tune came back but it was still revving weird so I pulled the maf sensor out and made sure it was in tight and clipped together good then it seemed to be good again but it revved up for on reason later that day and wouldn't drop back down besides that one time it was good now this morning my tune seems to be gone again? Any ideas I got my intake and throttle body used so I didn't have an instructions but it all seemed pretty Stright forward idk tho?
Old Apr 23, 2011 | 10:24 AM
velociabstract's Avatar
Default Re: New mods something Isnt right need help
You have a leak somewhere. My guess would be the throttle body, loose hose maybe, but that's the area you should look since the symptoms started after changing it.
Les
Old Apr 23, 2011 | 10:59 AM
94Bravada's Avatar
Les
That's what I thought at first too but everything seems tight and if it was a leak shutting the car down and restarting it wouldn't get rid of it I wouldn't think and would that mess up the tune if there was a leak
Old Apr 23, 2011 | 11:15 AM
MMZ_TimeLord's Avatar
It IS possible that it affected your tune as it would be receiving new and different data than it was designed for.
Suggestion: Pull off the throttle body and put back the old one, resetting the everything with the battery disconnected during the swap. Then try it out and see if the symptoms persist. If not, then it's the new TB. Simple process of elimination.
Old Apr 23, 2011 | 11:18 AM
That's a good idea. I read somewhere how easy the throttle body gasket gets messed up so be careful and take a good look at it when you get it apart.
Les
Old Apr 23, 2011 | 11:45 AM
robjob941's Avatar
I have experience in this and based on what im hearing its yor throttle body gasket. its a very cheap thing ( under five bucks if i remeber right) but the trouble of it is that you most likley have to order one and that takes days.
Old Apr 23, 2011 | 12:11 PM
If the gasket material is paper or another common gasket material, you should be able to pick up a sheet at any good auto parts store and make your own by tracing the original. If it's metal, order a new one.
Old Apr 23, 2011 | 12:36 PM
Regardless of what it is, it is the classic sign of a leak...I wouldn't have done the tune until all modding is done...anyway...I would do as suggested above...or, just take everything back off, check the gasket, check fitment, put it back on..but something didn't line up or seal for sure, also look at all you hose connections, even the one's you thought you didn't touch,,lol...Good luck with it...
Old Apr 23, 2011 | 12:53 PM
The OEM throttle body seal is a Viton O-ring. Replace this when taking of the T/body. It gets flattened and chewed up pretty good. Rekah has a good photo of his old one.
The O-ring is #2-151(Viton) 3 3/16" OD x 3" ID x 3/32 Dia.
Chrysler charged me $15 for it, at an industrial suppler it should be a couple of dollars max.
The Chrysler part number is in the photo below.
The Mercedes #3059970345
Old Apr 23, 2011 | 01:00 PM
PitMarshall's Avatar
I have a EuroCharged tune planned for next week. There are currently no mods to my motor except K&N filters. I have purchased a used 74mm TB as well and it will not arrive in time for the tune. I'm part of a group tune being done remotely over the Internet and the timing for things just won't work out. And so, I asked about the potential to do a future re-tune after the TB is installed and what the cost would be for that.
The EuroCharged folks are just awesome and the refrain of their customers is absolutely true. They told me that as a customer, once my TB was installed a re-tune could be scheduled at a mutually convenient time at no further charge ! How great is THAT!
Once you get the TB installed and the issues corrected, do not hesitate to ask Eurocharged to help out. BTW, that O-ring that 180 has posted above cost me $12 with taxes at my local MB dealer. A little on the high end I know but it was quick and painless and now it's off my to do list.
Old Apr 23, 2011 | 01:07 PM
My take on this is simple...why tune something, you know you are going to change? Put it all on there, and then tune it...thank god Jerry, Clint, and Jake are all patient, but if everyone does this, I think my patience would wear thin...
Old Apr 23, 2011 | 01:28 PM
From what you say you did not put the larger MAF unit on, so we can ignore that. You have to swap the OEM MAF sensor to the larger MAF unit.
Did you replace the 'O-ring' on the T/body?
Did you reinstall the two vacuum lines properly?
It's possible that the the NW CAI is now supplying more air than the MAF can adjust to? I'm not sure on that but you would have been better to get the tune after the mods, but I guess you knew that.
Old Apr 23, 2011 | 01:31 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Yeah but that has alot to do with age.....
Old Apr 23, 2011 | 03:19 PM
94Bravada's Avatar
When I talked to Jake I had told him that I was added the mods later in the week and he said the tune should be good with those I figured he took them in account when he flashed it and I am pretty sure he was right because the car felt real good with the stuff on the only problem was the tune keep coming and going I found that when it would rev and not come back down was only if I touched the gas as it was still warming up I pulled the 74mm off and the gasket was a bit messed up so I ordered a new one but I think there might be something messed up with the 74 it's self because I put the stock one on and it seems fine so idk and I am not sure if I should go up to a bigger maf? Is that something required with a single nw intake?
Old Apr 23, 2011 | 03:33 PM
There is a routine to test the throttle position sensor in the throttle body. That may be a bit tricky though, the write up is in the shop manual.
Apr 28, 2016 02:04 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
brandoni
Sep 30, 2015 07:48 PM
Sep 28, 2015 07:40 PM
