low engine idle
Old Jun 6, 2011 | 03:12 PM
BRappaport's Avatar
Question low engine idle
My car typically idles around 500 rpm and dips down to 400-450 rpm once in a while, especially at lights and becomes a rough idle. If I give it a little gas, or put it in neutral to raise the RPM up tp 600 RPM, all is fine.
Therefore, is there a way to raise the idle about 100 RPM so it idles at 600 RPM instead of 500 RPM?
Thanks
Ben
Old Jun 12, 2011 | 08:21 AM
BRappaport's Avatar
Default Re: low engine idle...how to adjust ???
Does anyone in this forum know how to adjust the engine idle on the Crossfire?
Any help would be appreciated.
Thanks
Old Jun 12, 2011 | 10:30 AM
kingkub57's Avatar
Not sure there is a way to adjust the idle ? since its controlled by the ECU. I would check to make sure you dont have a vacum leak somewhere, or that something is loose and not moving around causing an intermintent vac leak, and have you tried a throttle reset yet ? you might want to do a thread search for this problem also. Hope this helps some.
xfClifford
Mar 3, 2021 04:52 PM
skeet370
May 15, 2018 12:57 PM
Snake Eyes
Sep 28, 2015 08:55 PM
spoiler
Sep 2, 2015 08:56 PM
axnguyen
Jul 21, 2015 11:41 AM
